inlet spacer
Old Apr 12, 2011 | 05:41 PM
herbcosworth's Avatar
herbcosworth
herbcosworth
Default inlet spacer
what does the inlet spacer do sorry to sound thick askin this question just wondered
Old Apr 12, 2011 | 05:43 PM
paddyrs's Avatar
paddyrs
makes ur inlet manifold bigger thus has more room for more air thus more flow
Old Apr 12, 2011 | 05:47 PM
herbcosworth
herbcosworth
ahhhhhhhhh i see now
Old Apr 12, 2011 | 08:05 PM
It's nothing to do with more room for more air, the train of thought is that the inlet trumpets in the plenum are so close to the cover that they get a shrouding effect, moving them away by means of spacing is thought to overcome this.
More air does not mean more flow.
Old Apr 12, 2011 | 08:10 PM
Rsmat's Avatar
Rsmat
So Tabs would i benefit having one on my stage 1 3dr..has in dont want more power but would it be more efficiant??
Old Apr 13, 2011 | 03:53 PM
paddyrs's Avatar
paddyrs
well thats what a engine builder told me when i was thinking of geting a hart inlet manifold said i did not need it and that was why
Old Apr 13, 2011 | 04:52 PM
Papillon's Avatar
Papillon
some say its good some say it makes things worse.
not too many hard evidence out there either.
Old Apr 13, 2011 | 05:12 PM
v man's Avatar
v man
Zee Germans are coming
get your self a 4x4 inlet matt
they flow more efficiant standard than a 2wd with spacer
if anything spacer the 4x4 item
Old Apr 13, 2011 | 07:18 PM
He told you wrong, no where near as simple as that(what he told you), any angle the air has to turn tends to slow it down, the sharper the angle the more it slows, the closer the trumpet to the cover the sharper the angle, but there shed loads more to consider in flow terms, a change of cam will upset the perfect set up, as this is very inlet tract length dependant for ultimate results, a shorter tract tends to give better top end, longer better mid range etc, some designs are just bad, like the cossie 2wd and 4wd imo, could have been a lot better, but I think ford were caught on the hop a bit with the whole cossie scene, a lot of the car was crap to be honest as performance cars go, but that was more to do with penny pinching by ford bosses.
Old Apr 13, 2011 | 07:21 PM
I would guess on a fairly std cossie like a stage 1, you'd be hard put to notice anything meaningful, I did have some data on back to back testing, but can't find at the mo, but the general gist was it moved the torque around a bit, bhp didn't change significantly, it did help torque though, and also seemed to smooth out the power curve a bit.
Old Apr 13, 2011 | 07:25 PM
paddyrs's Avatar
paddyrs
i can understand that tabetha thanx
Old Apr 13, 2011 | 08:27 PM
v man's Avatar
v man
having the spacer or better a 4x4 inlet seems to give a better throttle responce also
so its not just about power gains here
if the car has a nicer feel when pressing the throttle down then that cant be a bad thing
Old Apr 13, 2011 | 09:21 PM
Rsmat's Avatar
Rsmat
Cheers guys ill prop gowith a 4x4 with spacer when i go blacks T34.63.
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
