Idle Problem?
Old Apr 12, 2011 | 01:57 PM
Ash170990's Avatar
Ash170990
Focus RS 0268
Default Idle Problem?
Hi Guys,
Took my car to superchips on friday for some bluefin..... and noticed that when i start it it idels at around 1k rpm.... then when im driving and put the clutch in (to change gear or stopping), it holds the revs at around 2-3krpm for a couple of seconds, But sometimes holds them to i come to a compltet stop, and then drops to 1k...... any body got any idea why its doing this and if it should be doing this?
Is it a problem with the bluefin map or is the clutch starting to fail but just a coincidence that it started happening straight after the remap?
I emaild superchips and they said it takes a while for it to learn everything again, but i did liek 250-300 miles over the weekend so thought that would be enough? They also suggested taking the bluefin off and seeing if i have the same problem on the standard map...so will probs give that a go at the weekend......
Also someone suggested it could be the lambda sensor.......so if it still has the problem after taking the bluefin back off i will try this....
Anyone got any other ideas what might be causing it if its not the map or sensor?
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
