Removing Handbrake Cable
Old Apr 10, 2011 | 11:31 AM
martysmartie's Avatar
martysmartie
Default Removing Handbrake Cable
Hi,
I have a new cable on the way so am removing my old one or trying to at least, Ive removed the cable from the operating levers, and everything else seems ok but I can't however remove the cable from the caliper, apparently according to the manual there is supposed to be a circlip, however on mine there does not seem to be on both sides there are just sold round bezels, i have tried to pry these off thinking this will release it but it still does not seem to want to budge, any help ASAP with this will be greatly appreciated as I want to try and have it removed by today.
Thanks,
Martin
Old Apr 10, 2011 | 05:14 PM
martysmartie
Not to worry, have sorted now.
Martin
Old Apr 10, 2011 | 05:21 PM
dojj's Avatar
dojj
Resident Wrestling Legend
brute force is the only way
Old Apr 10, 2011 | 07:46 PM
martysmartie
Thats what it was in the end, surprisingly though mine did not have the circlips, are they still avaliable from Ford?
Martin
Old Apr 10, 2011 | 08:39 PM
dojj's Avatar
dojj
should be, but i think most peole simply don't put them back in again once they remove them
or they lose them
Old Apr 11, 2011 | 08:00 PM
Mine didnt have any clips holding the cable to the caliper.
Old Apr 11, 2011 | 08:02 PM
dojj's Avatar
dojj
they've probably not been put back mate
i know they are a pain in the arse to get out and keep safe and seeing as they are really needed i can see why no one puts them back
Old Feb 26, 2020 | 06:43 PM
qed296's Avatar
qed296
I know this is an epic thread revival but ive got a question off the back of this.....
Can i just swap the cable without having to worry about bleeding the brakes afterwards?
Old Feb 26, 2020 | 07:41 PM
Caddyshack's Avatar
Caddyshack
yes you can
Old Feb 26, 2020 | 07:44 PM
qed296's Avatar
qed296
Brilliant, thanks for that.👍
Old Feb 27, 2020 | 12:50 PM
martysmartie
As a tip, make a mark on the actuator positions, relative to caliper position, before removing.
Martin
boeb
Jan 9, 2020 05:11 AM
muz
Sep 30, 2015 08:29 AM
Orion_Gav
Sep 29, 2015 04:50 PM
