closed loop lambda sensor?
Old Apr 8, 2011 | 08:24 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Default closed loop lambda sensor?
What lambda sensor is used with msd closed loop system? Can you use oe one and can you use an be after market one
Old Apr 8, 2011 | 08:36 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have one to sell that MSD supplied when i had there closed loop chip.Only done a max of 2000 miles and comes with the wires to the ECU. £35 + post if you want it or you can collect it at Central Day if your going.
Steve
Old Apr 8, 2011 | 09:11 PM
Arnt they easy to wire up.There are only 3 wires.
Old Apr 9, 2011 | 04:00 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Is that a standard ford one? Can an after market lambda be used with msd system?
My car has the standard lambda but by changing the turbo there is nowhere to screw it into. I'm going to weld a boss into the downpipe for a sensor. Guess what i'm asking is, would the standard lambda or an after market one be best to use for closed loop system?
Old Apr 9, 2011 | 07:00 PM
Just make sure it is a decent make, I'm sure the MSD ones are the excellent BOSCH widebands, like shown above.
Old Apr 9, 2011 | 09:06 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Cossie4i, is that standard ford one? What is the thread size?
Old Apr 10, 2011 | 08:57 AM
dakunia's Avatar
dakunia
This on picture abowe look like Bosch sensor from MSD closed loop kit, it has M18x1,5 thread.
Std cossi sensor mounted on turbo housing is M12x1,25mm thread.
Weld on lambda boss on downpipe after turbo and then fit unit as above, or buy std Ford sensor - available through Stu @ MSD from memory.
regards
maciek
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
