Assorted bits
Old Apr 8, 2011 | 08:56 AM
biggiejody's Avatar
biggiejody
Default Assorted bits
Looking to clear my garage and raise some funds. All stuff is plus post or pick up. The rear beam would need picking up or might be able to deliver withen reason.
A 99% complete rear beam. Was sandblasted and etched primered then painted withblack hammerite. Hasnt been fitted to a car. Brand new set of poly bushes fitted. Brand new rubber pipes. Callipers are good maybe needs freeing up but were working fine. New wheel bearing in box supplied. One hub is needing painting to match. Marks from storage nothing major. Without diff. SOLD
2 saph grills.no centres. One is a whiter white and one is diamond white
£20 each
A 2 piece exhaust. Not sure if
2wd or 4x4
£SOLD
Pair of 4x4 back lights. Not cracked but will double check
£25
Front polybush kit for 2wd. Gotta check they are all there first SOLD
T34.48. Needs a rebuild as it swallowed a stone. No cracks in the housing £PROV SOLD
Nearly complete set of aux hoses in red made by samcos. Not sure whats missing will put a pic up.
£30
Inlet manifold with regulater yellow injectors fuel rail throttle body. But no iscv valve
£75?
Will updated later when i get home and look in the garage.
Cheers jody
07825 799702. Located near heathrow m3 jct 1
Old Apr 8, 2011 | 08:59 AM
biggiejody's Avatar
biggiejody
2 piece exhaust is actually a 2 piece exhaust manifold
Old Apr 8, 2011 | 09:06 AM
biggiejody's Avatar
biggiejody
Also front and rear saff bumpers in white. Think the clips on the front are knackered and few stone chips. Laguna splitter, foglights, and surrounds included. £75 front £ 50 rear
Rear bumper has a split about 5 inchs long near the exhaust
f
Old Apr 8, 2011 | 05:12 PM
AndyR1's Avatar
AndyR1
hello interested in the hoses ,wots the best price posted,cheers andy
Old Apr 8, 2011 | 07:47 PM
biggiejody's Avatar
biggiejody
Ill do them 30 posted as theres only 3 hoses. Think there are supposed to be 5 of them. Ive got a picture of them if you send me your email ill send them.
Old Apr 8, 2011 | 10:41 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Have you got a price in mind for the turbo?
Old Apr 9, 2011 | 12:00 PM
biggiejody's Avatar
biggiejody
make me an offer as ive no idea what its worth, as it would need a rebuild to be used, although it still held boost at 7psi and pulled like a train lol
Old Apr 25, 2011 | 09:56 AM
biggiejody's Avatar
biggiejody
upski
rear beam, front polybushes, gone
also have a standard 3 door airbox with unknown performance filter, vgc no cracks all lugs and clips intact. £30 plus post
WILL TAKE OFFERS ON ANYTHING need it gone will get pictures up toady
Old Apr 25, 2011 | 11:42 AM
cameron2's Avatar
cameron2
Still got the turbo?
Old Apr 25, 2011 | 11:48 AM
biggiejody's Avatar
biggiejody
have the tps aswell but loose at the min
tatty with a crack in the pic £25?
compressor blades bit dirty as been in garage
back turbine blades inside
whiter white no marks, diamond white bit gruby
think its the bottom rad hose?
cheapo strut brace, small crack where it bolts to the strut top, painted satin black (not brill)
rear lights and numberplate surround, drivers side has two small dents in the bottom plastic, dont think will show on car
what ever hoeses these are, some samco. think smaco s are aux hoses
unknown steering wheel fits a saph
also some engine mounts, ignition amp wiper stalk and indicator stalk for a saph
Old Apr 25, 2011 | 11:58 AM
biggiejody's Avatar
biggiejody
yep still here
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
chowfornow
Sep 19, 2015 10:47 PM
