Ford Puma Discuss the Ford Puma here!
help my puma
Old Apr 5, 2011 | 07:25 PM
mikko888's Avatar
mikko888
Default help my puma
hello .... i need a mans advice for my puma 1.6 16v .... I want to start the engine has to change ... let's say a badget initial € 2000 .... what do you recommend? and that would increase hp?thank's
Old Apr 5, 2011 | 08:16 PM
LukeDaisley's Avatar
LukeDaisley
wow yoda. you can turbo a 2.0l or 1.8 for less than €2000.
Old Apr 6, 2011 | 04:29 AM
mikko888's Avatar
mikko888
thanks man .... basically you can fit a Cosworth engine?
Old Apr 6, 2011 | 05:35 AM
fonfe123's Avatar
fonfe123
You could fit a yb but in fwd format its not gonna be great to drive. For rwd or 4x4 setup ur lookin at a lot more cash.
For less than 2k have a 1.7 lump thrown in with frp cams inlet and map and u'll be happy.
Ex missus used to have an frp and yes they may only be around the 150bhp mark but is cracking to drive and sounds great.
Cheap conversion to do using genuine parts so is just a simple nut and bolt job. Use a normal 1.7 ecu and loom and have the ecu reflashed by pumaspeed, puma build or any ford dealer that has an frp map saved to their ids
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
Ben26
Sep 3, 2015 07:55 PM
