AB07 inlet valve clearance
Old Apr 4, 2011 | 03:55 PM
BRAMMER's Avatar
BRAMMER
Default AB07 inlet valve clearance
AB07 inlet valve & piston clearance question
I have spoken to Kent regarding the clearance and this is the info i was given - what i was asking was did they produce this cam with clearance on skimmed heads and here's the info i was given:
9 thou (1/4mm) TDC and 2mm valve drop
So from the info i was given what would be the last size head it would work without pockets?
I run standard Cosworth pistons and a Grp A gasket
Old Apr 4, 2011 | 05:09 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No idea but my head has had a skim and my valves don't hit.
Steve
Old Apr 4, 2011 | 05:11 PM
Nash's Avatar
Nash
Cake lover!
I would phone Grove and get them to ask Ahmed the question tbh.
Old Apr 4, 2011 | 05:25 PM
BRAMMER's Avatar
BRAMMER
Should have phoned them first actually but didn't think, will phone them tomorrow Adam
So what he basically said was if it doesn't drop and sit on the piston at TDC with at least 2mm of travel then they will touch when running at full rpm of 6500 i think that is right
Old Apr 4, 2011 | 05:33 PM
Nash's Avatar
Nash
Cake lover!
I dont have his email anymore Chris or i would send it over to you so you could just get him direct.
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
