803 Injector Dimensions.
Old Apr 4, 2011 | 02:11 AM
Heathen's Avatar
Heathen
From: A Small Island Somewhere In The South Pacific
Default 803 Injector Dimensions.
I need to replace my 803's as they aren't keeping up and i'm trying to find a replacement which doesn't require a fitting/wiring kit (a direct replacement).
These are the injectors I am going to buy if they fit:
http://www.msel.co.nz/epages/motorsp...ducts/INJSD63H
Can any of you give me the dimensions for 803's so I can compare them...
(the supplier has already given me the dimensions for the Siemens injectors)
Old Apr 4, 2011 | 05:54 PM
Why not measure your existing 803's ?
Old Apr 4, 2011 | 08:19 PM
Heathen's Avatar
Heathen
If I were anywhere near them I already would have done that instead of coming here.
If anyone has any measurements it would be greatly appreciated.
Old Apr 5, 2011 | 11:04 AM
Stu @ M Developments's Avatar
PassionFords Creator
Here you go, direct replacemnt and dimensions listed.
http://shop.motorsport-developments....ance-235-p.asp
Your listed ones are wrong impedance for the ECU by the way.
Old Apr 6, 2011 | 05:18 AM
Heathen's Avatar
Heathen
Thanks alot for the info, that's a great help!
(I was aware of the difference in resistance, but I have a Link ECU anyway)
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
dombanks
Sep 21, 2015 08:38 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
