Mondeo coolant overflow
Old Apr 1, 2011 | 08:09 PM
Firebird1's Avatar
Firebird1
Default Mondeo coolant overflow
I have a 1.8L petrol Mondeo 2002 which has done 80K miles. The problem which has just started, is that after a run, there is a small patch of coolant on the drive. This coolant is coming from the overflow channel in the expansion tank. The amount of coolant loss is so far not high.
There have been several suggestions that 1. the head gasket maybe starting to break down, 2. the water pump maybe faulty, 3. the expansion tank maybe faulty, 4. the expansion tank's pressurised cap maybe faulty. The running temperature is normal.
I have replaced the cap which seems to have reduced but not eliminated the coolant overflow. I am thinking about changing the tank next, although I can't see anything wrong with it but maybe the cap is not making a good seal. Do you think that it could be either the head gasket or water pump, or something else?
Old Apr 1, 2011 | 08:34 PM
JonathanJ's Avatar
JonathanJ
replace the cap first , cheap and could well be the cause
Old Apr 2, 2011 | 07:07 PM
Check your de-gas pipe is clear, as these block easy, esp the restrictor in the tank stub.
Old Apr 2, 2011 | 07:52 PM
Firebird1's Avatar
Firebird1
Thanks tabetha--I am not sure what you mean, can you plse explain further. What's the de-gas pipe?
Old Apr 2, 2011 | 08:13 PM
martysmartie's Avatar
martysmartie
The de-gas pipe is the thin hose that comes from the expansion tank.
Martin
Old Apr 2, 2011 | 08:57 PM
Firebird1's Avatar
Firebird1
Thanks Martin. The expansion tank has 3 pipes connected to it. One larger one from the tank bottom which will be the main feed to the engine, & 2 smaller pipes at the top of the tank, From memory, I think that one goes to the radiator, the other I'm not sure. Are you suggesting that one of these smaller pipes might be blocked?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
