T5 gearbox, koni's, t34 + more...
Have the following bits left from my 2wd saph, can take the smaller bits to central day if needed.
T34/.48 usual spec 360 bearing etc has a brand new Collins actuator no play no smoke no cracks in the rear housing only ever run 16psi just over 2 years old & covered 5k.
£400.
Koni adjustables with 30mm springs, good clean condition, no leaks & all adjust fine. Comes with adjuster key.
£175.
Stage 3 kit, green 803's, 3 bar map sensor & pj motorsport chip for L6 with t34.
£200.
Stage 1 Techni-clutch organic clutch, fitted in october last year, Was in a stage 3 car never slipped under hard boost.
£75.
2wd mongoose exhaust, centre box removed 3" pipe with 3" outward rolled tailpipe. Generally in good nick, has a flat spot before the last bend near back box. Cleans up well.
£120.
Bailey 2wd header tank, has had a repair in the past but was fine on the car.
£45.
Unknown make 2wd stainless header tank, 2 dents in the top.
£30.
Brand new 2wd rear calipers, discs & pads been fitted & done no more than 20 miles.
£120.
Front standard 4 pots, look new but not sure as they was already fitted when o got the car, again new discs & pads.
£120.
Have a moonstone shell has scabby arches & poor paint. May sell as a complete shell or will split has good 4x4 bonnet, boot, kit, bumpers?
Have virtually a full car as was only bought for the engine so have most other parts, nay post some items to the UK only.
Thanks James.
07956-082-784
£400.
£175.
£200.
£75.
£120.
£45.
£30.
£120.
£120.
Thanks James.
07956-082-784
james i take it the car was 2wd ,
do you have the pair of stub flanges off the rear shafts mate ,
they bolt to the driveshafts and into the hub carrier
its the section with the splines on bud
Yes I do beefy mate, was hoping to leave the shell rolling but getting alot of intrest in the hubs & beam so will completely nut & bolt it!
Going to begin stripping it Sunday some time so will let you know if alls ok with them.
I also have:
Moonstone blue front bumper in VGC & complete ready to bolt on.
£110.
Moonstone blue 4x4 bonnet again in VGC no major stone chips etc with vents.
£100.
Moonstone blue bootlid with spoiler, no rust or dents but slight laquer peel in both back corners.
£60.
Full recaro leather trim with door cards, pretty poor condition IMO but good for a retrim maybe?
£150.
Full blue samco boost & water hoses in exellent condition. Has t34 intake hose, & bottom left water hose is red!?
£100.
Good 2wd prop-£50.
Stainless header tank has a few small dents-£35.
Will add more over the weekend.
£110.
£100.
£60.
£150.
£100.
Good 2wd prop-£50.
Russ Payne
Sep 25, 2015 08:29 PM
