AP brakes under Sharktooth wheels
Old Mar 31, 2011 | 02:36 PM
Char1ie's Avatar
Char1ie
Default AP brakes under Sharktooth wheels
Well, I finally took a couple of shots. AP calipers, discs and bells. 295 X 25mm discs, CP5100 calipers. DS2500 pads - I should really get DS3000 but this was just a test fit. They squeeze in to a standard 4X4 Sharktooth alloy with about 0.5mm clearance - all on a 2WD Sapph.
Charlie
Old Mar 31, 2011 | 04:43 PM
RS SHAUN's Avatar
RS SHAUN
Bloody he'll Charlie, they look a tight fit, NICE THOUGH mate!
Old Mar 31, 2011 | 04:47 PM
Cilly-jey's Avatar
Cilly-jey
looks mint pall
Old Mar 31, 2011 | 04:53 PM
clocky280's Avatar
clocky280
Thumbs up well nice m8
well nice m8
Old Mar 31, 2011 | 05:05 PM
ram's Avatar
ram
Has a large member
Looks stealth! love it. wouldn't fancy running a 0.5 mm clearance though! the slightest wheel flex and you scraping. you gonna put some spacers on?
Old Mar 31, 2011 | 10:28 PM
axelriet's Avatar
axelriet
0.5mm is not going to be enough... The wheels will flex and the wheel bearings too.
Besides that, not sure about the pads: fast road kits better stick to fast road pads, or you risk boiling the fluid and/or warping the rotors (comp. rotors are 32 or 36mm thick and flow a lot more air in addition to be much more robust, and comp. calipers for rotors of that size have titanium pistons and/or water cooling to avoids transferring too much of the vastly increased heat generated by comp. pads). Your wallet will also love the increased rotor life... YMMV of course, just my 2ct
Old Mar 31, 2011 | 11:35 PM
crumpet's Avatar
crumpet
lattices fit too?
Old Apr 1, 2011 | 03:23 PM
Char1ie's Avatar
Char1ie
I doubt lattice wheels will fit - they didn't fit over my old calipers without a tiny bit of rubbing and they have less clearance in the spoke area.
Sharktooths are strong wheels - I don't think there will be any flex but I'll find out first time I race it.
Going to go with DS3000 pads or maybe Mintex 1166 (I think) for racing - just need to pull out the wallet and buy some.
I do have wheel spacers - 5mm I think so may use them.
One thing I'm struggling with at the moment is bleeding the bloody things. I have massive girling cylinders - 2.5 inches across - and I want to use a Pressure bleeder but the universal adaptor cap that comes with the Sealey pressure system is shit and won't hold pressure so I think I need to make a new cap with an airline pressure connector valve thing connected to it. What a pain! Anybody have any bright ideas?
Charlie
Old Apr 1, 2011 | 06:23 PM
Nash's Avatar
Nash
Cake lover!
Charlie do these caliper run the same pads as a 5200 series? I have a few packs of Mintex race pads i have had for a few years, not sure on the number will need to look.
Old Apr 1, 2011 | 06:28 PM
Char1ie's Avatar
Char1ie
Thanks Nash but the pads are a bit smaller.
Charlie
Old Apr 1, 2011 | 06:32 PM
Kverna's Avatar
Kverna
Virgin-popper
Would love to see som rolling shots of the setup. Looks bad ass
Old Apr 4, 2011 | 12:12 AM
dazzle740's Avatar
dazzle740
Surely 0.5mm of clearance will not be enough especially if your tracking it as well as i'd the heat generated whilst on the track would make the calipers expand slightly????
Old Apr 4, 2011 | 11:17 AM
Char1ie's Avatar
Char1ie
We will find out
I think they will be OK but will probably use 2mm spacers to be sure.
Charlie
Old Apr 4, 2011 | 11:31 AM
paddyrs's Avatar
paddyrs
wonder could i do this to my 4x4?
Old Apr 4, 2011 | 11:38 AM
Twellsie's Avatar
Twellsie
doubt it, 4x4 disks have far less offset
Old Apr 4, 2011 | 11:56 AM
paddyrs's Avatar
paddyrs
Old Mar 18, 2012 | 07:56 PM
daz1968's Avatar
daz1968
Sorry to bring up an old post but does anyone know if this setup would fit behind 3 door wheels as I want to improve my brakes but would like to keep standard wheels if possible, have thought about changing wheels but have changed my mind.
Thanks
yatta
May 21, 2016 10:31 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
