ford escort rs turbo s2 parts JOB LOT GOTTA GO PICS ADDED
FOR SALE IS ALL THE PARTS I HAVE LEFT OVER FROM BREAKING MY S2. LIST AS FOLLOWS: JOB LOT GOTTA GO
'88 SPEC REAR SEATS
'88 SPEC DOOR CARDS
1X FULL STAINLESS EXHAUST SYSTEM(MONGOOSE)
1X SCORPIAN BACKBOX
T2 TURBO
1X GEAR BOX
FULL SET OF 50MM LOWERING SPRINGS ( pi )
2X BODY KITS
GLASS-REAR,REAR QUATERS,FRONT DOORS.SUNROOF
4X HEADLIGHTS
2 sets CLEAR INDICATORS
1X DUMP VALVE
1X SET OF REAR LIGHTS
INTERIOR TRIM-FULL SET
4X DRIVE SHAFTS
CHIPPED ECU(HEARTS AND DIAMONDS)
FUEL ECU
1X COMPLEAT AND MINT DISH
2X ELECTRIC MIRRORS
2X STANDARD INTERCOOLERS
2X HEADER TANKS
2X HEATER UNITS
1X BRAND NEW IN BAG BOOT LOCK SET WITH 2X KEYS
2X RADIATORS
SPARE ALLOY GOOD TREAD
ABS UNIT
5X BREAK DISCS
T3 TURBO OIL FEED PIPE (BRAND NEW)
DISTRIBUTOR UNIT WITH BLUE CAP
MFI INLET
3X ENGINE MOUNTS
REAR HUBS
2X REAR DRUMS
3X BREAK CALIPERS
1X PARCEL SHELF WITH SPEAKER HOLES
1X CHARGE PIPE
4X FRONT HUBS
1X FRONT ANTI ROLL BAR
CHROME ROCKER COVER
2X TINS (SMA MILK TINS) FULL OF NUTS BOLTS WASHERS ETC ETC
ASSORTMENT OF HOSES
2X OIL FEED PIPES
'88 SPEC REAR SPOILER
1X BONNET
1X ALTINATOR HEAT SHEILD
1X FUEL TANK
I HAVE PROBABLY MISSED LOADS OF STUFF OFF WILL ADD ANYMORE BITS AND PIECES AS I FIND THEM
you can collect or I can post
can meet half way at a cost
PLEASE PHONE 07733061889 IF YOU HAVE ANY QUESTIONS or pm me on here (phone is quicker)
thanks pete
more stuff
cam cover
2x speaker cover
1x sterring wheel cowling
1x fuse tray cover
1x k&n filter
2x wish bone bolts with nuts (long blue ones)
1x set of bonnet hinge's
1x horn
1x battrey+ altanater cable
1x abs sensor
2x oil feed pipes (like new)
1 x fuel cap with key
1 crome fuel cap with
1x gearbox cradel
1x un none rs spoiler
1x amal valve with pipes
1x steering wheel
loads more to add
http://s691.photobucket.com/albums/v...%20rs%20turbo/
Ł500 O.V.N.O
'88 SPEC REAR SEATS
'88 SPEC DOOR CARDS
1X SCORPIAN BACKBOX
T2 TURBO
1X GEAR BOX
2X BODY KITS
4X HEADLIGHTS
1X DUMP VALVE
4X DRIVE SHAFTS
FUEL ECU
2X ELECTRIC MIRRORS
2X HEADER TANKS
2X HEATER UNITS
2X RADIATORS
ABS UNIT
5X BREAK DISCS
MFI INLET
3X ENGINE MOUNTS
REAR HUBS
2X REAR DRUMS
3X BREAK CALIPERS
1X CHARGE PIPE
4X FRONT HUBS
CHROME ROCKER COVER
ASSORTMENT OF HOSES
2X OIL FEED PIPES
1X BONNET
1X FUEL TANK
thanks pete
more stuff
cam cover
2x speaker cover
1x fuse tray cover
1x k&n filter
1x horn
1x abs sensor
1x gearbox cradel
1x steering wheel
loads more to add
Ł500 O.V.N.O
if it dont sell on there make me a offer plus p+p
rear seat's very clean other than a small mark on the top. will wash out
driveshafts gaters are all intacted teeth not chipped
header tank... no pipes no leaks come with cap been used
thanks pete
matman
Sep 9, 2015 05:45 PM
