Pump+wiring
Formerly know as Puss
Hi guys my first thread in here
Just got a saph its not been used for a couple of years and want to change the fuel pump and pump wiring. I believe you can get a new wiring kit were is the best place?
here you go check out the link it is easy to do much cheaper than paying Ł50 for a loom do it yourself
https://passionford.com/forum/techni...re-wiring.html
Here you go! this is how I done mine, I ran a new 32amp +&- cable direct from the battery through the bulkhead and run it inside the car to the boot area using the old pump feeds to switch a new relay which I atached to the fuel pump cut off switch bracket.
