A couple of niggling problems
Old Feb 6, 2005 | 11:51 AM
Rob84's Avatar
Rob84
Default A couple of niggling problems
I've just bought K3v ha's car a.k.a DOO's old beast and i'm VERY happy with it, but theres a couple of minor gripes.
1. going slow in 1st gear, tckling speed bumps etc, the engine/box clunks abit, as if a mounts gone. is this the case and if so, are uprated mounts available to buy?
2. when reversing, with a bit of right lock, the offside rear disk vibrates rather loudly, as if its binding only does it in reverse though. A simple case of the caliper sticking slightly?
thanks ppl
Old Feb 6, 2005 | 01:16 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Sorry, is this a Beantin?? I will assume it is. Sorry if not!! LOL.
1. Vibratechnics Engine Mounts. DEFINATELY the way to go. IMO, those and a B&M Shifter will get rid of all the unwanted movement in the Engine/Gearbox and consequently, you wont feel the movement through the gear lever.
2. If it has had a Cossie Rear Disk conversion, the chances are the outside edge of the disc is touching the caliper. Try loosening off the bolts and lever the caliper out a bit, then re-tighten. If this isn't enough, then file a little bit out of the inside of the caliper where it is touching.
Hope this helps.
pabloXR
Sep 21, 2015 12:42 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
