Brembo brake caliper fitting
Old Mar 25, 2011 | 11:23 PM
robbo9006's Avatar
robbo9006
Default Brembo brake caliper fitting
What part do i need here .
I bought all the kit
Brembo calipers.
Brackets to fit focus rs calipers to a st24 brackets
Focus RS discs.
The holes in the calipers seem to going the wrong way.
Ok i have seen a pic of a carrier.
Any eone a part number.
I suppose ill go to Ford (dread)
BREMBO P.N. 80.040
I found the part i need and there quite cheep
BREMBO P.N. 80.040
Old Mar 27, 2011 | 07:21 AM
robbo9006's Avatar
robbo9006
Default brembo mounting brackets 130mm
i need a set of these 130mm between the stud centres and either 130mm holes like these and then use my conversion bracket.
Or straight into a 3 1/2 " hole senario.
This means they will bolt straight onto my st24 then.
Is there anyeone making these.
jason_nike
Aug 18, 2019 10:53 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
