Cosworth Fan problem
Old Mar 24, 2011 | 07:10 PM
chrisa3's Avatar
chrisa3
Default Cosworth Fan problem
Just got my saff running for the first time since last summer. Started fine, everything running mint.
Problem is this:
When the fan cuts in, it spins up fast for a second or two and then immediately slows down to a very slow pace and the left side indicators and both side lights are lit up constantly. The fans run at this pace constantly. If i turn the engine off, the fans and lights continue for around 1-2 minutes and then all shut off together.
Anybody got any ideas to point me in the right direction. Wiring / electrical problems aren't my forte
Old Mar 24, 2011 | 07:16 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Relay or fuse box problem?
Old Mar 24, 2011 | 07:33 PM
chrisa3's Avatar
chrisa3
I hope its not the fusebox. I cant remember it doing this last year and I havent changed anything other than the horn. Thought it might be a bad earth somewhere, but im a bit lost at the minute.
Old Mar 24, 2011 | 09:23 PM
JonathanJ's Avatar
JonathanJ
Check if they share an earth , if it has gone a little corroded over winter the fans will "search" for an earth and it is finding it through the bulbs and as the bulbs cannot transfer the current that the fan requires and they take some power to light that is why they are glowing . Just my thought late at night
Old Mar 24, 2011 | 09:53 PM
chrisa3's Avatar
chrisa3
Just spoke to a friend of a friend who whos an auto sparky and thats exactly what he said to the letter
Old Mar 25, 2011 | 10:57 AM
Most odd faults like this are usually earth related, I would run new wires/relay to the fan if not done so as well.
Old Mar 25, 2011 | 01:30 PM
martysmartie's Avatar
martysmartie
As said above sounds an earth issue, check and make sure the earths are clean, more than likely they are corroded and you then end up with the situation explained above, basically electricity wants to get from positive to negative as quickly as possible and will take the shortest path possible, so the corrosion will add resistance and so it takes another path in this case illuminating your lights, a bad earth will also cause the fans to act as they are.
Also the fan loom was substandard to start with and this is why nearly all of us have rewired, the fuel pump suffers a problem with the old wiring building resistance and so the pump cannot get the power it needs under load, this can lead to an engine meltdown, you can buy the looms pre made or it's not that hard to DIY.
Martin
Old Mar 25, 2011 | 03:34 PM
chrisa3's Avatar
chrisa3
Martin
Thanks. Ive cleaned all the earths up and will give it a go tomorrow. the car idles mint, nice and smooth, but on applying the throttle, it splutters and black smoke appears a little too. I think the ignition amplifier shares the same earth, so im hoping this could be th reason for that.
im running AGPR12PP8 plugs and they were gapped at 0.8mm so i have dropped them to 0.6mm which is what people appear to set them at, incase its a plug gapping issue causing the spluttering.
Old Mar 27, 2011 | 08:21 PM
gcfcos's Avatar
gcfcos
similar thing happened to mine when original fan fuse and relay melted in fuse box against other wires/fuses in box
Old Mar 27, 2011 | 09:26 PM
chrisa3's Avatar
chrisa3
Turned out to be a bad earth behind n/s headlamp. Cleaned them up and all working now.
markk
Dec 2, 2021 06:59 PM
CLIVE
Oct 2, 2015 12:58 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
