Another stuck bolt!!
Old Mar 24, 2011 | 07:08 PM
matt_jagger's Avatar
matt_jagger
Default Another stuck bolt!!
Ok, it's mega stuck, rounded off and I want to cry.
Can anyone help me with some extra ideas on how to get this bolt out.
It's the number 4 bolt holding the injector in the block on my 1.8 TD transit connect.
I have replaced all 3 of the injectors but this one is faulty and it's the only one I really needed to change!! ha ha.
Ok, I tried
Day 1
almost a full can of WD40, 6 + hours of soak.
Heat to the point of cherry red and pipe freeze in cycles.
the 10mm head rounded :-(
Day 2
I bought the Irwin remover kit............total bobbins, won't grab it enough to turn with any force and further chewed the bolt head.
It's just under 10mm spanner width now, but I can't wedge a screw driver head in to compensate due to not being able to swing the spanner in any way to losen the bolt due to space.
It won't take a 9mm socket, 10mm socket slips, I can't get grips into it as it's slightly sunken and I couldn't get any force on it anyway if I could.
Properly peaved off!!!!
HELP!! ha ha.
Old Mar 24, 2011 | 07:15 PM
fraser9764's Avatar
fraser9764
dill the bolt head off, remove the injector, plug the hole to stop any crap going down there and then a set of long nose mole grips should wind the thread out. im guessing its stuck because of the torque on it, rather than siezed in the head.
ive never looked at transit connect injectors so this might not be possible but ive removed plenty of bolts this way.
Old Mar 24, 2011 | 07:18 PM
Cossy Mike's Avatar
Cossy Mike
need a piccy......
Drill a pilot hole and use a big ease out.
weld a nut on the top??
can't say without seeing it
Old Mar 24, 2011 | 07:20 PM
LukeDaisley's Avatar
LukeDaisley
I feel for you. 3/8???
Old Mar 24, 2011 | 07:22 PM
Turbosimpsons's Avatar
Turbosimpsons
as said weld a bigger nut on top. remove it while it's still hot.
Old Mar 24, 2011 | 07:23 PM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
try and hammer a 9mm socket on there or weld a bar or there
Old Mar 24, 2011 | 10:53 PM
matt_jagger
Cheers lads, really appreciate the advice.
I tried the 3/8th slipped again :-(
I think I'll dremel off the head of the bolt as advised. I can see this being the best option. It's defo over torqued not siezed in there.
I'll hit the threaded shaft with the heat and wd40 and I will have space to fit in some grips too.
I'll post a piccy so as to show how the injector is held in, and how badly the access is to a silly 10mm bolt, and also the mess it's in ha ha
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
muz
Sep 30, 2015 08:29 AM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
