OAP Pete
Old Mar 22, 2011 | 08:19 AM
OAP Pete's Avatar
OAP Pete
Default OAP Pete
"Kevlar" timing belt !, seen these advertised on Net... 300 times stronger claim !, Guys what your opinion... any hear got one fitted...3 times the cost...is the standard one perfectly adequate. Ive 2 spare at moment "Gates" and "Graham goode". Pete OAP.
Old Mar 22, 2011 | 08:41 AM
james kiely's Avatar
james kiely
nothing wrong with the standards pete ,maybe for a rally /race car,but for a road car the gates and goode ones are fine
Old Mar 22, 2011 | 11:32 AM
Look at it from a cynical point of view like I do, WHY would it need to be 300 times stronger ?, did no timing belt ever survive before this new type ?
The std material is well up to transmitting enough force to open the valves etc, as it has/does on millions of cars day in day out.
Now ask what material the std belts are made from, usually made from rubber with high tensile fibres of fibreglass, twaron, which is nearly enough identical to KEVLAR, being a para aramid fibre, twaron has been about since 1970 when developed, by AKZO.
You've likely used it already without realising, so NOTHING new 41 years old!!
Old Mar 22, 2011 | 03:40 PM
OAP Pete's Avatar
OAP Pete
Default OAP Pete
Thanks Gentleman, keep what ive got...agreed full Race / Rally hour after hour may be. Regards to all OAP Pete.
Old Mar 22, 2011 | 04:02 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Makes you wonder how the Touring cars finished a race .
If there was something better than the standard one it would be on mine be assured .
Old Mar 22, 2011 | 04:50 PM
OAP Pete's Avatar
OAP Pete
Default OAP Pete
Your right...guess im just paranoid when i do go out in Car...its going to Snap!... Pete
Old Mar 22, 2011 | 07:08 PM
Paul_RS's Avatar
Paul_RS
Are the standard ones not kevlar anyway?
Old Mar 22, 2011 | 07:17 PM
OAP Pete's Avatar
OAP Pete
Default OAP Pete
Dont think they can be ! as "Kevlar" belt as advertised by Amber performance.." Ł110. 3 times standard i guess. OAP Pete.
Old Mar 22, 2011 | 07:26 PM
martysmartie's Avatar
martysmartie
Standard item is rubber/fibreglass.
Remember the belt isn't always the problem, the tensioners can let go!
Martin
Old Mar 22, 2011 | 08:05 PM
Most oe fitted ones are now Twaron, not FB.
warleydaddy
12
Aug 10, 2015 06:31 PM
Eagle
14
Sep 27, 2004 10:04 PM
Eagle
Sep 5, 2004 09:42 PM
Jim Green
16
Aug 17, 2004 08:25 AM
Smit
24
Jan 12, 2004 11:53 PM
