2wd cosworth diff mount
Old Mar 20, 2011 | 02:37 PM
BIG MULL's Avatar
BIG MULL
Default 2wd cosworth diff mount
hi, my rear diff mount is now passed it and wanting a replacement but as you can no longer get an original one from ford any more, i am wanting to know if the new cnc ones are any good or do you get vibrations or transmission noise thru the car as its a road car and not a track weapon?
cheers.
Old Mar 20, 2011 | 06:59 PM
I have tried a std one, a std one poly filled in the voids, and a full poly one.
The only thing I noticed was a SMALL amount of vibration, so small you keep forgetting about it, as it is really is only minor, I also found a drumming sound on mine when the fuel tank was at a certain level and I was doing a certain speed, a simple stick on acoustic pad that cost me Ł6 cure it 100%, as it took the resonant frequency outside that the mount could create.
The difference is night and day in terms of car control, you won't regret it.
If a bufty and wanting the std/ish look these can be poly filled and work perfectly, at least as well as the after market full poly ones, but at way under 1/2 the price.
Old Mar 20, 2011 | 08:10 PM
BIG MULL's Avatar
BIG MULL
cheers tabetha,
when you say you used the sticky pad where did you stick it exactly?,
and how do you polly fill a std one and how long would it last bud?
cheers for the reply
Old Mar 20, 2011 | 10:17 PM
As I'd only just put a new tank on mine I dropped it enough to stick the pad on top, I put it on the top as thought it would eventually become detached if on underside, I'm not sure but think I may have stuck one on the bottom as well to start with, but it's certainly not there now, but most don't have this problem, no one else has mentioned it anyway, most people in the car didn't even notice, maybe it's my cossie paranoia!!
The std one can be poly filled, my mate did a few for me, one of which is in Iceland on a 1/4 mile sprint car, it's been perfect, how long would it last ?, it would outlast the normal type of poly rear imo, it simply adds resistance to the std one so no fitting issues, and last one cost me Ł25 to do, the mount is sealed on one side, then held so the top surface is level, then filled with poly slowly so no air bubbles, and allowed to set, makes a massive difference to stiffness, over a much much larger area than the "std" poly type.
Old Mar 20, 2011 | 10:43 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
why would it out last the normal type of polly ones lol you are just filling in the voids over the rubber each side of a standard one also the ones you buy have a much smaller flexy part so less likely to wear out as it will not move about as much and mine bolted on no harder than a standard one did
Old Mar 21, 2011 | 10:27 AM
BIG MULL's Avatar
BIG MULL
Thanks for the replys lads the info is a big help
Old Mar 21, 2011 | 07:07 PM
Why would it outlast ?, it has the same force spread over a much larger area.
My poly one also bolted on no bother, even with my tow bar metal work there, and my 22mm custom/adjustable rear arb.
Old Mar 21, 2011 | 07:23 PM
ajamesc's Avatar
ajamesc
im not saying it wont last but it will not out last one of the ones you can buy and no way out perform it as yours is just polly around the rubber mount also being a bigger surface area it will flex more also the ones you can buy are a small ridged bit of polly with 2 bolt tubes sandwiched between too plates so a very solid item with almost no flex in it which is what you are after as you are tryeing to stop the diff from moveing lol their is always a cheaper way of doing things but its hardley ever a better way lol
Oct 9, 2015 07:38 PM
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
xr4x4rs
Aug 6, 2015 09:03 PM
