Fuel Surge / Starvation?
Just fitted a new uprated pump to my car, an intank 255lph pump. Which sits in the same place as the old pump inside the pump carrier.
Now if i corner hard the car cuts out and then once ive straightened out again it re-starts (obviously in gear), ive tried it both ways, cornering left and right.
Would it be fuel starving?
i had a similar thing with my fiesta, turned out to the the TPS wires shorting out... did it more on cold mornings, and only when turning left, sometimes wouldnt start again for ages replaced it and all is well
prob got a crappy pattern part fuel tank fitted and the new pumps hi flow is just amplifying the prob you will most likley get at just under 1/4 of a tank in hard corners. Thats my experience anyway.
