electric problem
Old Mar 19, 2011 | 07:34 PM
delterflier's Avatar
delterflier
Default electric problem
hi
my 03 plate focus just scraped throw the mot today
now i have a problem with the lights,nearly every time i press the brake pedel the side lights come on
any ideas or common faults?
cherrs john
Old Mar 20, 2011 | 09:58 AM
Check for water ingress on the rear light clusters and their connectors/bulb holders.
If still no joy take out brake light bulbs and see if it fixes the issue, it's sounds like water ingress across either the light board tracks or connector etc, but 99.99% sure you'l find the problem at one of the rear lights.
Old Mar 20, 2011 | 10:36 AM
RichieST's Avatar
RichieST
Deffo rear lights. either bulb holders or someone's put an incorrect bulb in there that's shorting across the terminals.
Old Mar 20, 2011 | 07:48 PM
delterflier
strange how you mention that as i just noticed after i bought a bulb from auto save and fitted it in rear passenger.
i knew there was a reason i dont shop there
cherrs john
Old Mar 20, 2011 | 07:49 PM
B19 JUB's Avatar
B19 JUB
yeah wrong bulb 100%.youve put a single filament bulb in instead of a double and its back feeding through the sidelight circuit
Old Mar 20, 2011 | 07:50 PM
delterflier
def no water or sing that there has ever been water anywhere nere the back lights
cherrs anyway
john
Old Mar 20, 2011 | 07:55 PM
delterflier
fraid not def twin filament bulbs in both
john
Old Mar 20, 2011 | 09:20 PM
RichieST's Avatar
RichieST
Have you taken both the rear bulbs out and seen if it still does it? If it has stopped, the bulbs are definately your problem! You could just unplug the holder that would probably be easier.
Old Mar 20, 2011 | 10:11 PM
delterflier
will give that a try 2moz
cherrs john
Old Mar 20, 2011 | 11:14 PM
martysmartie's Avatar
martysmartie
Im with the above with wrong bulbs, the fact that both are doing so as well, that or you have a wiring problem but doubt it!
How do you know the sidelights come on though, seen as they both share the same bulb and when the brake lights are on as they are brighter than the sides you woulden't be able to tell, or is it when you come off the brakes the sides come on?
Martin
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
