sierra p100 speedo
Old Mar 16, 2011 | 10:38 PM
mikehill's Avatar
mikehill
Default sierra p100 speedo
hi owned my p100 a couple of months now and want to convert it to 4x108 using a capri axle but i am unsure of what this will do to me speedo
the capri axle i am going to use (i think lol) is out of a laser so its a 3.75:1 diff whereas the p100 has a 4.65:1 i think
any help would be great thanks
Old Mar 16, 2011 | 10:44 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
did this on my own p100 last year and the speedo was fine mate
Old Mar 17, 2011 | 08:27 PM
mikehill's Avatar
mikehill
what axle did you actually use been thinking of 2.8 lsd but its only a 1.8td so don't really think it warrants this
Old Mar 17, 2011 | 08:31 PM
wulliesxr4i
GIT-R-DONE
a put the one out of a 280 brooklands that was gettin broken, mines was also a 1.8td and the diff didnt afect the speedo at all mate,
Old Mar 18, 2011 | 07:47 AM
"diff don't affect speedo"!!!!!!!!!!!!
Of course the diff, or rather as asked in this case affects the speedo accuracy, as I assume the speedo is driven from the gearbox output.
Changing ratios will then affect your speedo accuracy, if you put a higher ratio(lower number) diff in there the speedo will under read,
look on www.kabamus.com/garage/gears.html
On this site just put in any combo of gearing you want, tyres sizes, gear ratio, diff ratio etc and get the exact answer.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
