Focus TD DI - Fuel leaking from somewhere!!
Old Mar 15, 2011 | 11:08 AM
fordfocustd's Avatar
fordfocustd
Default Focus TD DI - Fuel leaking from somewhere!!
I have a 99 Focus 1.8 TD DI and I have a fuel leak. I thought it was coming from the solenoid at the bottom of the fuel pump ( Bosch VP30 - 047 0004 007 ).
Any help or direction will be greatly appreciated.
However now I'm not sure it is that solenoid that is leaking.
Last night we took out the alternator to get a better look and there does not seam to be any obvious leaks. The left hand side where it bolts into where the pulley sits look damp but apart from that looked ok. So bolted everything back together and made sure all was tight including the fuel lines to the injectors. Also resealed the thermostat housing as that was leaking fluid too.
Ran the car and there was no obvious leeks. Got underneath and there seemed to be a small amount of diesel dripping from the alternator bracket which to me suggested the back of the fuel pump where we couldn't see anything.
If anyone has any ideas I'd love some suggestions to my problem!!
Old Mar 15, 2011 | 11:09 AM
fordfocustd
Angry
No the car seems to be getting worse!!
Driving to work this morning and the car has now lost power!! As if the turbo isn't boosting but had a quick look under the bonnet and couldn't see any problems.
Any ideas??
Old Mar 16, 2011 | 02:51 PM
fordfocustd
Any ideas??
Ok so the intercooler sensor plug had fallen off so reduced boost. Plugged it back on and all pucker again.
However I still have this pescky fuel leak!!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
taylora1409
Aug 12, 2015 12:06 PM
