quickest way to remove trailing arm on sapphire....
As title...
I need to change the drivers side one on my 2.0 dohc sapphire as the spring burst through the bottom of it. I cant see an easy way to remove the front 2 bolts that run through the bushes of the arm.
Does the whole axel have to be dropped to change them??
hmmm... id thought about that but it looks like the bolt closest to the diff, has to come out in the direction towards the diff.
I just know its not gonna be handy
oh yeah, forgot about the inner one, wont come out with the diff there. To save messing about just drop the whole back end out rather than trying to remove the diff with everything in place, all the fiddling will take you longer in the long run.
rsguy
44
Sep 29, 2015 03:29 PM
Fudgey
Sep 17, 2015 01:06 PM
