4x4 sapphire spring poundage advice...
Old Mar 13, 2011 | 09:17 PM
mattygreen's Avatar
mattygreen
Default 4x4 sapphire spring poundage advice...
After finding one of my springs has cracked, I've decided to get some custom springs made as my mate can get some made at a good price. Car is phase 3 spec - approx 350bhp with koni shocks - any advice appreciated
Old Mar 14, 2011 | 01:17 PM
martysmartie's Avatar
martysmartie
I would go with the Leda Ahmed Bayjoo springs or the AVO chassis dynamic springs, the Ahmed ones will lower the car around 10MM and the AVO are avaliable in standard height but are uprated.
Martin
Old Mar 14, 2011 | 09:09 PM
mattygreen's Avatar
mattygreen
Thanks for the advice, but can get some custom springs made for less than half the price of those, anyone know what poundage standard springs are?
Old Mar 15, 2011 | 10:20 AM
The information is available on the net, have a search.
Old Mar 15, 2011 | 10:42 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
just ring one of the companys that sells them up saying your thinking of buying a set and ask them what poundage they are
Old Mar 15, 2011 | 03:50 PM
mattygreen's Avatar
mattygreen
Tried that with Graham Goode and Demontweeks... Just got told they are around 15-20% stiffer than standard.
Old Mar 15, 2011 | 04:04 PM
ajamesc's Avatar
ajamesc
Ring someone who knows what there talking about lol try gaz blackart avo people like that mate
Old Mar 15, 2011 | 07:15 PM
F99 REV's Avatar
F99 REV
900 pound rears is wot im running with no sagg on boost, tried 700 and they still sagged like a bitch!!
Old Mar 15, 2011 | 07:22 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
............do u not have struts aswell...??.......
Old Mar 15, 2011 | 08:31 PM
F99 REV's Avatar
F99 REV
STRUTS?????????
Old Mar 15, 2011 | 08:37 PM
mattygreen's Avatar
mattygreen
Must be the forum dunce... Did a search before I posted post a link so I can have a read thanks....
Old Mar 15, 2011 | 08:55 PM
pete mcrash
STRUTS?????????
......struts are you're dampers....."struts n springs"...........it was a joke cos u seem to be running springs that are 3-4 times stiffer than everyone else....
Old Mar 15, 2011 | 08:59 PM
F99 REV's Avatar
F99 REV
FUNNY! every other cossie saggs on boost, mine dont thats the difference
Old Mar 15, 2011 | 09:03 PM
pete mcrash
.......right then...guess u know best then.......and why the .....u a fuckn internet warrior..??
Old Mar 15, 2011 | 09:07 PM
F99 REV's Avatar
F99 REV
yer something like that......
Old Mar 15, 2011 | 09:20 PM
mattygreen's Avatar
mattygreen
So 300ish pound - that standard or up-rated springs
Old Mar 15, 2011 | 09:27 PM
pete mcrash
i dont have konis, so i couldnt tell ya...but i have Gaz coilovers and have 325 front and 175 rears (as advised by others).....but i think the rears are too soft (so i adjust the struts)......i'd say on my set up 300 front and 225/250 rear.....but thats just me....suspension is a twat to sort out as its personal taste..........
Old Mar 15, 2011 | 09:41 PM
mattygreen's Avatar
mattygreen
Thanks for advice, mine is fitted with Ahmed track spec springs, which people say are supposed to be the best? My cars not running massive power circa 350 bhp and when on boost was like a speed boat lol... Not sure if this is due to cracked spring as only found out spring was cracked after changing wheels - maybe jacking car disturbed the spring? Like you say is going to be an arse to get right...
Old Mar 15, 2011 | 09:43 PM
gavt123's Avatar
gavt123
darrens cossie with koni shocks and 900lb springs work bloody well it rides smooth and doesnt bang around when just plodding along but when you give it the beans it feels solid and planted and it doesnt drag its arse along the floor, have you not been in it matt?
Old Mar 15, 2011 | 09:48 PM
pete mcrash
.........try a propper diff mount...??
Old Mar 15, 2011 | 10:49 PM
Mike1's Avatar
Mike1
I can tell you the std 3-dr Springs were 106 lb/in front - 263 lb/in rear, Sapphire 2wd were 118 lb/in front - 286 lb/in at rear.
I've got the 4wd rates somewhere so I'll have a dig
Old Mar 16, 2011 | 12:42 AM
crumpet's Avatar
crumpet
900 lb? LOL where from?
Old Mar 16, 2011 | 02:23 AM
R5FORD's Avatar
R5FORD
900lbs springs wtf thats like double a hard coilover
Old Mar 16, 2011 | 02:27 AM
crumpet's Avatar
crumpet
exactlly^
Old Mar 16, 2011 | 02:40 PM
mattygreen's Avatar
mattygreen
Thanks Mike, but after reading what Pete said he's running on his sapphire, I thought that can't be right as he would be running less than standard on his car at the rear. Anyway... after alot of digging around I've found out that a 4x4 runs 140lb on front and 120lb on rear, also avo coilover springs are 300lb on front and 200lb on rear.
What I can't get my head round is... that would give a 115% increase on front and only 67% increase on rear.
Would make what Pete said about right as you feel your 175lb springs are too soft, so if they were up-rated applying the 115% increase on front that would make approx 258lb
Still not convinced though as everytime I see a sapphire either 2 or 4wd on full chat the back end always looks like it's only a few inches from hitting the road lol....
Old Mar 16, 2011 | 02:52 PM
ajamesc's Avatar
ajamesc
I have gaz coil overs and mine dont suat as my 45 profile road legal sliks dont rub! dont no what rateing they are but gaz will know also there not even set that hard but i am still standard hight
Old Mar 16, 2011 | 04:31 PM
F99 REV's Avatar
F99 REV
custom made mate
Old Mar 16, 2011 | 04:36 PM
F99 REV's Avatar
F99 REV
your springs will be done for friday matty 600lb rears will colect car satday night so make shore it got a full tank call it Ł85 cash!!!!!!!!!!
Old Mar 16, 2011 | 08:48 PM
R5FORD's Avatar
R5FORD
I cant see how running 900lbs springs os a nice ride and how it does no damage from the continous stress
Old Mar 16, 2011 | 09:42 PM
Mike1's Avatar
Mike1
Fair enough - the figures came from SVE themselves though. Remember there are less active coils on the rear hence the higher rate as well. Those figures were for standard springs not coilovers by the way that I gave you.
Anyway, sounds like you are sorted now
Just don't get confused between people giving you rear coilover ratings as opposed to normal mounted position springs - coilover springs are a different diameter as well on rear
Just as an aside have a look at the manufacturer figures for ther various E30s ( similar sort of car to a Sierra ) in the article below and then see if you think the spring rates I gave you are still wrong
rog
Sep 16, 2015 03:00 PM
tib2220
Sep 14, 2015 12:33 PM
Topjoe9
Sep 12, 2015 09:50 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
