Transit Connect- Now Starts but leak oil like mad.
Old Mar 12, 2011 | 02:38 PM
Tank Mike's Avatar
Tank Mike
Default Transit Connect- Now Starts but leak oil like mad.
Firstly, thanks to everyone who replied on my non start thread.
Upon it starting its revealed quite an issue.
It leaks oil like mad from behind the crankshaft pulley. I removed it all when I got the new engine to fit a new timing chain. When you start the engine oil comes out the seal like mad!
Anyone had this. I've tried the old pulley and another seal and it still comes out!
Old Mar 12, 2011 | 04:12 PM
Icurus's Avatar
Icurus
Was there an oil slinger fitted on the inside of the front cover that you might have forgotten to re-fit? I think the old Kent engine had a similar device to keep oil away from the circular seal?
Old Mar 12, 2011 | 10:41 PM
Tank Mike's Avatar
Tank Mike
The oil pump sits directly behind the pulley in the timing chain cover. And I didn't take the oil pump apart so I'm guessing no. There's nothing like that
Old Mar 13, 2011 | 03:20 AM
carcollector's Avatar
carcollector
dont complain, its a built in feature, its called clutch lubrication
Old Mar 13, 2011 | 09:56 AM
Tank Mike's Avatar
Tank Mike
Its the other end
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
