i.c.e help reqd please
Old Mar 12, 2011 | 07:46 AM
simonwwfc's Avatar
simonwwfc
Default i.c.e help reqd please
rite ive got a alpine 45w x 4 amplifier cde-9801r head unit that in going to power just door speakers (upgrading today) ive got a vibe cbr 10" active subwoofer with built in amp . now unsure how to set 3 buttons on amp
1 : 180 phase 0 button
2 : crossover 40 to 160 hz
3 : level button min to max
any help please as just going into my transit connect
Old Mar 12, 2011 | 01:58 PM
Blue-Oval-Bass's Avatar
Blue-Oval-Bass
The phase control will help with any delay in the lower frequencies , basically if the low end seems out of sync with the midbass and vocals.
The crossover will cut the frequencies above or below what u want the speaker to play.
The level control { IS NOT A VOLUME CONTROL } is there to match input to output levels.
Your alpine has a bass engine built in to help set up and a basic eq for the midrange.
If your stuck give me a shout.
Old Mar 12, 2011 | 05:23 PM
simonwwfc's Avatar
simonwwfc
top man many thanks got it all up and running was a bloody mare running power lead from batt to back but got there in the end with help from wife . ive got the treble set on 3 to give door speakers a bit of tinie sound bass set on zero to stop any coming from door speakers as bought 2 way alpine sxe-1325s 200w peak power 35 watt rms cheapys Ł39 quid from halfords . have got sub woofer setting on head unit on 12 but goes to 15 ? got cross over set about 3/4 and volume around same ? if u fancy a trip to aylesbury or meeting half way more than welcome lol
Old Mar 12, 2011 | 05:58 PM
Blue-Oval-Bass
Set the vibe x over to @70hz that way it should cut most signal after 70hz
your headunit has a bass engine with boosting points , if its lacking low end up the 50hz setting.
Similar with the mids , the headunit has a basic eq to up certain mids frequencies , your just gonna have to play around with it til you get the sound you want.
You can buy bass blockers to cut low bass from your mids if its distorting.
Come up to the big audio day at icedot.com in mk nxt sunday or i can pop over if you cant get it sounding how you want it.
Old Mar 12, 2011 | 06:30 PM
simonwwfc's Avatar
simonwwfc
many thanks pm details for sunday il pop over
neil1983
Oct 2, 2012 07:57 AM
FestaRST
Alloy wheels and ICE for sale
Mar 15, 2007 01:03 AM
adamS2RST
Fiesta RS1800/RS Turbo
22
Jun 18, 2004 08:51 AM
adamS2RST
14
Feb 22, 2004 03:28 PM
