Door hinge pins
Old Mar 12, 2011 | 06:37 AM
cossie330's Avatar
cossie330
Default Door hinge pins
Hi, does anyone know best way to remove door hinge pins on a saff?
Cheers Jason
Old Mar 12, 2011 | 07:24 PM
If I remember right they are a roll pin ?, in which case I'd use my scissor remover or slide remover.
They are effectively knocked out, or pulled out.
Old Mar 12, 2011 | 08:15 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
a normaly undo them from the pilar with the 4 nuts holdin them on,
Old Mar 12, 2011 | 08:31 PM
Char1ie's Avatar
Char1ie
Me too - dashboard off then undo the hinge where it bolts to the shell. Charlie
chowfornow
14
Jan 5, 2019 09:01 PM
muz
Sep 30, 2015 08:29 AM
mpilk
Sep 27, 2015 09:21 AM
Fudgey
Sep 17, 2015 01:06 PM
