cosworth 2wd clutch problem?
Old Mar 11, 2011 | 06:37 AM
rich123's Avatar
rich123
Default cosworth 2wd clutch problem?
hay all just wonderd if any 1 has had this,when driving i have to flick the clutch pedal before the clutch will engage properly then its ok for a bit but still every now and again i have to flick it again,thought it might be my clutch ratchet (quadrant) etc
thx all
Old Mar 11, 2011 | 06:42 AM
MAD Ade's Avatar
MAD Ade
More than likely to be the clutch ratchet, should still be able to get one from Ford.
Old Mar 11, 2011 | 06:48 AM
rich123's Avatar
rich123
is there a diffrence between a standerd sierra and a cosworth clutch ratchet
Old Mar 11, 2011 | 07:00 AM
MAD Ade's Avatar
MAD Ade
Yes, I think there is. You need a white one (you will need to count the number of teeth on your one)
Old Mar 11, 2011 | 07:09 AM
johnyjn's Avatar
johnyjn
What did i tell you rich.............
jessie_rs
11
Jun 3, 2019 04:57 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
