Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Turbo/ExhaustManifold bolts.
Old Mar 9, 2011 | 01:35 PM
clayton's Avatar
clayton
Default Turbo/ExhaustManifold bolts.
Will 8.8 High tensile bolts be ok with the heat on the exhaust manifold and turbo flange/donwpipe?
Thanks
Old Mar 9, 2011 | 09:55 PM
RickyLee53's Avatar
RickyLee53
Yes they should be fine, use some spring washers to keep them from coming off.
Old Mar 10, 2011 | 07:53 AM
clayton's Avatar
clayton
ok thats good to know.... do the spring washers ever loose there spring? i see you can get the spiked washers that look better...
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
The Sludge
Technical essay Archives
May 6, 2007 06:57 PM
Cosworth Bassie
20
Apr 27, 2007 10:25 AM
foreigneRS
Jul 20, 2004 11:06 AM
