Steering q
Hit a couple of potholes last week in my van the steering started pulling to one side I've had the wheel alignment done twice now and it's still doing it what you thinks been damaged it's a 2008 fiat scudo
Sounds like something is bent, even though the tracking is perfect, if one wheel is slightly further back, ie the hit one this will cause what you have.
Get a helper and with a tape measure measure between the wheels each side of the van, from centre of the wheel, they should be within around 1/4" from side to side.
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
