3dr and frs mk2 lenth.
Can somebody Give me the 3dr cosworth and the Mk2 Frs lenth`s....as my Frs just fitted in the garage with 2" spare...Hopefully the 3dr will fit.. If not into storage while my new garage gets built.
Cheers Mat.
Cheers Mat.
Mat, here ya go buddy, right hand side of the page...
http://en.wikipedia.org/wiki/Ford_Sierra_RS_Cosworth
Just type in google for FRS..
And another.
http://www.carfolio.com/specificatio.../car/?car=2189
And another.
Sierra is bigger than a Focus, so no if you only have 2" to spare then it's not going to fit.
Should think Focus is around 14 foot at the most (So far as I know FRS is no different)
Martin
Martin
pics
See what they say but I just can't see it, bearing in mind the Focus MK1 is 164 inches, this would mean the MK2 Focus is a foot longer which isn't correct I suspect it's a few inches if anything. Interestingly it also states the FRS is 4 inches longer than the MK2.
Keep us posted though as I would be interested to know if it does fit or not
Martin
Martin
Martin
Martin
Will do mate ...cheers....
My Mk2 ST wouldn't fit into my garage with a storage unit at the end, and my old st170 fitted ok. Had to take the unit out and my ST just fits, so it is definately longer!
We also have similar cars bar the colour
Martin
As I say I should think the Focus is around 14FT at the most so a few inches more than the previous Focus, a Mondeo is what replaced the Sierra and so comparable in size but even this was smaller, the Sierra is also quite "Boxy". The Focus replaced the Escort and so a hatchback, the Sierra a saloon.
But if OP'S garage is 15FT then it will just fit.
Martin
Martin
Ive got a cossie 3dr n mk2 focus rs sales brochures at home which have the measurements of the cars in. When i finish work if your question hasnt been answered by then i will post them up.
In January 1985, the brochure had the following lengths:
3/5 door 173.5" Estate 177.4", except
Ghia - 5 door 174.2" Estate 178.0"
XR4i 3 door - 175.6" l
I don't suppose the 3dr Cosworth will be very different from the XR4i.
it will defo fit inside 15ft
i was amazed at how small a sierra actually is compared to newer cars my 3 series is harder to get around in the garage over the sierra and the coupe boot and rear leg room is shocking in bmw,where does it all go as sierra has a long bonnet
i dont think a 3 door can be longer than a saph,im sure i read the estate and saph are identical length and hatchback 2 in shorter
have you not realised that new cars are getting bigger and now not fitting into uk parking spaces??
the mk4 mondeo is HUGE compared to the mk3!!!
You are correct though Saph is 2" longer (As I state above) but the Estate is longer than the Saph again by about the same amount.
Martin
Kiran1600E
11
Oct 2, 2015 11:35 AM
only joking pete x
