ABS and Master Cylinder Kits
Hi, sorry if this has been asked before, I have searched...
could anyone please tell me where to get rebuild/refurb kits (seals etc) for both the ABS block and master cylinder assembly for a 3 door, Ford do not list them.
Many thanks for any help, PB
Thanks dojj for the response, a little surprising given how many of these cars are around and how many are being restored - there are places here is Aus who will do replacement seals to a sample, I will get some done and see if anyone on PF is interested, cheers PB
For the record, a company called Past Parts can do refurbs/reconditioning of most parts. Needs sending to em and they can re-bore and seal accordingly.
Link here.
Link here.
Link here.
Link here.
They do seal kits aswell if you tell them the size casting numbers ect
Plenty of them mate, but there was a change from about 88/89 when they went with the separate valve block on the other side of the engine bay and some pumps have the gibbons reversed as the v6 models had heat issues where as the dohc ones had the exhaust on the opposite side so didn't need to worry about hot exhaust gasses warming up the pump and fluid
The granddads had them as standard so more likely to get bits
New master cylinder £44+vat to my door from local factors.
