sapphire 4x4 green top lambda test strange
Old Mar 6, 2011 | 07:30 PM
iguman's Avatar
iguman
Default sapphire 4x4 green top lambda test strange
When I connect led tester to my L8 ecu and unplug Lambda sonde dont get any errors, but when I try to do Co adjust get 1 blink in 2 sec what means that is out of range. Same thing when i connect Lambda sonde...
When engine is started i get error 3+1 - Lambda sonde but in manual say that can be possibly "out of range" of adjustment. I try to adjust co screw but all the same...
Sone ideas?
Old Mar 9, 2011 | 04:05 PM
iguman's Avatar
iguman
Someone?
Old Nov 7, 2011 | 11:49 AM
iguman's Avatar
iguman
Does someone have experience with this?
I dont know how to adjust Co level on different way on cossy green head
thanks
Old Nov 7, 2011 | 11:46 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Unless tou know what your doIng it's best left to a cossie pro when it comes to adjusting co levels. People been known to blow their cossie engine by messing around with them for MOT's
Old Nov 9, 2011 | 10:57 AM
Yura's Avatar
Yura
to reset CO screw adjustment and set it to base settings need - 5 turns clockwise and 1.5-2.5 turns anti clockwise.
then check CO by CO meter - it should be about 1% at idle(950rpm)
jason_nike
Aug 18, 2019 10:53 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Bailes1992
Aug 16, 2015 07:14 PM
RsS2daz
Aug 14, 2015 05:26 AM
Old ford
Jul 31, 2015 06:50 AM
