Ford Ka
Hi all im new on here so bare with me.
Iv got my girlfriends old ford Ka and i know that the Focus 1.8 and 2.0ltr engines fit but dose the st 170 fit as im planning a swap.
All advice would be good
cheers wilba
cheers wilba
tough 1 lad did u try look up the http://www.kaklub.co.uk/ theres alot of conversions on the with rst and 2.0rs engines.
Track Designs site lists all the engines you can use their mounts with - very clear info.
Our Engine Mount Kit Allows the following engines to be fitted to a KA:
Zetec 1.8 silvertop
Zetec 2.0 silvertop
Zetec 1.8 blacktop
Zetec 2.0 blacktop
1600 CVH
RS Turbo CVH
ZVH o Zetec Turbo
Focus ST170
Focus RS Duratec
dunno could you use the ka gearbox though itd be the job if you could
Zetec 1.8 silvertop
Zetec 2.0 silvertop
Zetec 1.8 blacktop
Zetec 2.0 blacktop
1600 CVH
RS Turbo CVH
ZVH o Zetec Turbo
Focus ST170
Focus RS Duratec
the engine will bolt to gearbox and you can use a track designs mount to fit the engine, although this puts all the mounting at the back and it will move too much imho. I am currently putting a st170 engine in a Ka, but using the st170 side engine mount.
Cool il check the website.
Iv read that the standard gearbox works well but the st170 engine i was offered cumes with a 6speed box would it matter if i dropped it for the standard Ka 1.
cheers wilba
cheers wilba
It can be done there is some one on www.fk-oc.Com that has one in his ka on TB's and there are a few members that make and sell mounts cheaper than track designs
Billy_RS
16
Oct 11, 2025 09:41 PM
borboyous
Aug 22, 2015 11:17 AM
