Pug 205 MI Conversion
Old Mar 5, 2011 | 08:02 PM
JamesyRS's Avatar
JamesyRS
Default Pug 205 MI Conversion
Hey guys, swapping my rs for my brothers mi16. My plan is to turn it into a track weapon but going to sort out niggly bits for mot first. Supposedly engine isnt sitting correctly hence the driveshaft problems but been on some pug websites and they only mention a uprated mount so it doesnt hit master cylinder but nothing about the inch spacer ive been told required could anyone tell me the score so I can sort it out? Cheers
Old Mar 5, 2011 | 09:27 PM
Spiky's Avatar
Spiky
this going to be a daily drive or track monkey?
Old Mar 6, 2011 | 12:48 AM
JamesyRS's Avatar
JamesyRS
both it going to be my run around at night as have work van during day but want to use it ona few track days possibly
Old Mar 6, 2011 | 08:14 AM
pee vee's Avatar
pee vee
didnt need any spacers when i fitted mine.
You sure the 'spacer' they are on about isnt for the exhaust manifold?
basically with the standard mi16 exhaust manifold, it can hit the bulkhead of the car,
so you need a little 'wedge' shape spacer to go between the head and the exhaust manifold.
What driveshaft problems are you having??
if the car was a 1600 gti and you are trying to fit an mi16 or 1900 gearbox, then the splines are slightly different IIRC.
Old Mar 6, 2011 | 11:31 PM
JamesyRS's Avatar
JamesyRS
hi mate its defo an inch spacer on the mount they are talking about, engine sitting to far back according to some people who have had a look. Maybe just need the uprated mount ive read about on sites? It just seems to eat driveshafts, it has a diesel gearbox in it. The shafts look like they need brought up so they are more level which would resort basck to this inch spacer thing if engine lifted at back the shafts would be alot straighter if you get me? They seem to be aiming into sky at moment.
Old Mar 7, 2011 | 06:47 AM
Spiky's Avatar
Spiky
sounds like it's be angled to fit (bodge) rathe than use the wedge,
ideally you want the engine sitting at the correct angle ( they are angled as std, just in case you didnt know)
get a wedge, get it sitting right and i suspect your drive shaft issues with go away
join the 205 drivers forum and search there, loads of info on there
Old Mar 7, 2011 | 06:05 PM
JamesyRS's Avatar
JamesyRS
where would I get wedge? and thanks will have a look on there later on thanks mate
Old Mar 7, 2011 | 08:14 PM
pee vee's Avatar
pee vee
i reckon i got one in the garage somewhere. they are quite a lot of money for what you get
only thing i dont know is, if i've still got the bolts to attach it to the head with
(they are allen key bolts with almost countersunk heads, so allow for the wedge shape)
Old Mar 9, 2011 | 10:38 AM
JamesyRS's Avatar
JamesyRS
be good if you did mate, so how I go about making engine sit right?
Old Mar 9, 2011 | 10:44 AM
Spiky's Avatar
Spiky
to have it sitting at correct (std) angle
driver mount must be std type (inc bbm one's)
bottom fork mus be std
and gearbox mount must be std,
thats it
Old Mar 9, 2011 | 11:48 AM
JamesyRS's Avatar
JamesyRS
so is it standard as in 205 mounts or the mounts for mi16? Also you dont have a picture handy of how radiator and fans should sit do you? He took them out and now when he puts rad back in it seems so sit way below fans, thanks for the info, trying to get help here as still working my way round the 205 forum
Old Mar 9, 2011 | 11:49 AM
Spiky's Avatar
Spiky
205 mounts
fans bolt to cowling, cowling slots onto the metal section on front panel, bery easy to see and fit,
Old Mar 9, 2011 | 04:11 PM
JamesyRS's Avatar
JamesyRS
hmmm it must be sitting correctly then, could it be previous owner has destroyed shafts by spinning its coont in? And will have a look tomorrow sounds easy enough, does rad sit in two holes on bottom crossmember if you know what I mean? this will be 1st 205 hence all the questions ave only had beamers and fords lol
Old Mar 9, 2011 | 04:24 PM
pee vee's Avatar
pee vee
yeah i seem to remember there being two pegs that slot in.. its been a while though, so could be wrong
if you need it
you can get an alloy rad off ebay for about £40 and they are brilliant.I had one, sure spiky has one too,
and you just never get any probs with them.
Old Mar 9, 2011 | 05:35 PM
JamesyRS's Avatar
JamesyRS
thanks for help, it has alloy rad so hopefully wont have a prob just couldnt work out where fans sat etc
Old Mar 9, 2011 | 08:58 PM
Spiky's Avatar
Spiky
Nissens rad are great
Rad fits into two holes on the back of the fan cowling
Very simple , so don't worry about it
Old Mar 10, 2011 | 05:04 PM
JamesyRS's Avatar
JamesyRS
think that problem it dont seem to have holes on cowling so trying to get a hold of second hand fans and new rad will sort it out that way thanks for help guys, still no closer on driveshaft poblems though, as all mounts standard, only thing I can think of is thrashing?
Old Mar 10, 2011 | 05:13 PM
Spiky's Avatar
Spiky
how do you know they are standard?
and that the bottom fork is standard?
Old Mar 10, 2011 | 05:15 PM
pee vee's Avatar
pee vee
what trouble are you having with the driveshafts, exactly mate??
Old Mar 10, 2011 | 09:43 PM
JamesyRS's Avatar
JamesyRS
guy that fitted it said they were, how would I tell? And problem is it destroyed drivers side cv joint and now passenger side is away, but toff on here owned one and he never changed a driveshaft so thinks engine sitting incorrectly.
Old Mar 10, 2011 | 10:11 PM
craig_007's Avatar
craig_007
Have a look under the car at the engine mount on the drivers side. There is an engine mount there.
This is the one that gets extended approx 15mm. Easy to see if it's been welded up. Mines was like this too and it affected my gear change. I stuck a standard mount on and reangled my down pipe to suit. It worked a treat.
I have since changed the down pipe to a 4-2-1 set up.
Has the lip on your tunnel been cut back where the exhaust starts to go under the car from the bulk head, If so my down pipe would likely fit your car, It's got a lambda boss welded in also. Yours for £40 notes if you collect it.
Old Mar 11, 2011 | 05:03 PM
JamesyRS's Avatar
JamesyRS
Will have a look tomorow is this mount on top or underneath? it has a 4-2-1 on it at present so no issue with exhaust clearance and dont look like bulkhead modified. Will check this mount out tomorrow morning and update. Cheers.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
