what engine, what bhp does it produce!
Now I still got a standard 1.6 turbo engine... Workin on a new one, also a 1.6 but totally worked out!
The one i've got now probably will run as fast as an xr3i, it's weak and almost got 200.000 on the clock.
The new one will if everything is working out run over 200hp but we'll see.. Have to hit the roller first to find out
Not sure what mine will produce when it is finished but it is reasonably swift at 14psi as it is...
Will be running a bit more than 14 when it's finished though.
It's a 1600 CVH BTW.
Originally Posted by rsturbo90
just wondering what different spec/types of engines u all have and what proven bhp u have got out of them
1.6 rebuilt useing 0.5 oversize pistons standard rebuild, head reconed by my tuner.
spec on rest of car
pro alloy intercooler and rad
piper cam
superchipped ecu
k&n airfilter
scorpion exhaust
silicon hoses
187 bhp at only 10 psi boost proven
boost can be turned up to 16-17 when warrentes run out looking at way over 200 bhp in the summer but may stay at this sort of power as dont want a reliabity issues.
total cost
proally cooler and rad was about Ł700
piper cam was about Ł200 with followers etc
k&n Ł50
chipped ecu and fitting seting up Ł300
exhaust Ł300
silicon hoses Ł80
engine and head rebuilt including fitting Ł1700
set cost Ł30 and all future set ups cost the same
so about Ł3000 all in gets u a quick car but then theres the gearbox and clucth issue that may or may not need addressing
spec on rest of car
piper cam
superchipped ecu
k&n airfilter
scorpion exhaust
silicon hoses
total cost
k&n Ł50
exhaust Ł300
silicon hoses Ł80
just got mine rebuilt havent got a clue what power to expect
1.6 cvh
low comp pistons
fully uprated bottom end (bearings etc.)
big valve head
piper 285 t2
hybrid t3
scorpion exhaust
other little things like samcos, bov, leads and filter
running it on a ahmed bayjoo ecu at the moment its set at 15 psi but i want to raise it to 20 psi and get a mf2 driver set up oh and of course intercooler and water spray!!! then im hoping for at least 210!
1.6 cvh
low comp pistons
big valve head
piper 285 t2
hybrid t3
scorpion exhaust
i have a 1.6 CVH
1mm oversize accralite pistons.
7.6:1 compression ratio.
'Stage 3' power engineering big valve head
stage 3' hybrid turbo (super 60 comp trim .48 ex housing)
new standard rods
Fully balanced bottom end (NMS)
Piper 285t cam
NGK 9's
usual extras ie exhaust, filter chip etc
and the raging fury of 12Psi
tis reasonably quick when on boost but i need to get it set up properly before i can run any big boost hoping to finish the build off with a T34 soon and 25+psi
hopefully arround 250Bhp
new standard rods
Piper 285t cam
NGK 9's
mine didnt have chance to go on the rollers as i only got it set up and finished 2 weeks ago and it got stolen and crashed last sat, so its being stripped now
Realy sorry to hear about the car.
Hope you get a chance to de-skin the c*cksuckers that took her and then roll them in gritting salt.
Hope you get something at least as good sorted out to replace her (if that's possible).
Oh, by the way, all steel 1597cc CVH running approx. 23 PSI from a T35 with charge cooler etc. etc. etc. 286bhp and 300 lb ft at just over 7000 rpm. Now turned down to about 260 brake to give the gearbox a chance of survival (tends to make swarf out of them). Built about 6 or 7 years ago at enormous cost and still going strong.
Short of a group 4 MK II or big power Cossie, the best fun you can have with your trousers on.
Cheers.
Cheers.
Yeah it does
It's very nice
That's not to say that being kicked up the **** would be nice.
But apparently according to one of my mates a long time ago, as a passenger 'it's like having a Recaro enema', but in a good way
Sort of got used to it now. 3rd, 4th and 5th gear acceleration on motorway still gets me though. It's quite bizarre, like being in a computer game.
When I originally got her, I scared myself so badly that it took both hands to get my bank card in the cash machine (possibly adrenalin) to get more petrol money after my first proper thrash.
She's like a sodding cocaine habit.
I have to stop myself from driving her so as to keep my license intact.
Still, she's padlocked in the garage with two cars parked in front of it and it's always raining, so I don't have to try too hard
Rain is the ultimate turn off - she tries to break traction at 105ish in 4th and will spin wildly in 3rd at 90 - not good when
All the best
All the best
Hi Bass boy, just typed out a realy comprehensive reply, Took me ages and when I submitted it all I got was a blank screen with invalid session at the bottom. I'll have to try it again sometime. I'm too knackered now.
Suffice to say, the car is black and was a privately owned Severn Valley Motorsport developement car.
It was featured in Performance Ford, August '98 Max Power and either Fast Car or Fast Ford between 1997 and 2000 (not sure of exact issues), so if you've got any of these they should make for some interesting reading. I wouldn't mind seeing them too
The spec was also listed on the SVM website but that isn't working at the moment.
Cheers and all the best.
I think i remember this car years back and i think in those days it had black wheels. It was featured in several magazines running around 285bhp and in one particular issue (dunno what mag) it was featured with a grey s2 which was running a 1.9 engine with just over 300 brake. I think both cars were owned at that time by svm. Will have a look at some of my old mags later on to see if i can spot it.
mines
-31 set to spike at 12ish now anyway, settles at 10.
kn
samcos
dv - soon to be coming off
serviced well, maintained well, 250bhp fuel pump,
mines proven to 158bhp..not chipped, when its chipped, or more to the point, if its chipped, LOL, ill see then.
kn
samcos
Yes, she still has the black wheels. They are factory satin black finished TSW evos (rare as hens teeth - i'm still trying to find a spare).
Both cars were privately owned, they just put the fake plates on for the articles to designate the tuning company and horsepower.
My friend Rob had purchased the car new in October of '89 as a birthday present to himself. He spent the next eleven years developing the car with various tuners and being ripped off by most of them.
He wanted big power and a linear/aspirated feel if at all possible.
He sort of achieved this by visiting SVM after he had just been extremely dissapointed by a well known South London race engine builder who had kept the car for six months and (among other scandalous things) had fitted a distorted crank from a blown up race engine in it. The engine was so bad that it barely made the drive to SVM and he kept having to stop and refill it with oil.
SVM salvaged the block (everything else had been ruined by the previous tuner or was just wrong for the engine), and set about creating a monster.
Kevan Kemp did this because he liked Rob so much and was so impressed by the look/condition of the car and wanted to use it as a business promotion. The net result was that Rob got a very very expensive engine at a good discount just for taking the car to a few photo shoots with some silly stickers on it.
The engine build was carried out by SVMs engine specialist, an ex Formula 1 engine builder called Ron Jones, and Kevan did the mapping and setting up as far as I am aware.
The Max Power article features the car shortly before the last of the big upgrades were made, so the Performance Ford one would probably be more up to date.
I think the other article (not sure whether Fast Car or Fast Ford) might actually have been from when the old girl had a Slater Motorsport 180ish BHP conversion and was featured with a red Slater car owned by a chap called Miguel (now sadly written off).
The Slater conversion was a lovely little package, easy on the transmission and very reliable and driveable. The car had RSi ratios at the time so made realy good use of the relatively low power.
The best treatment Rob ever had was by a nice chap called Russel Clark who used to race a Turbo in the Vecta Fast Ford series about 12 years ago and did various bits and pieces to the car in it's infancy.
I only ever met Russel once or twice and I think he is now a professional race instructor.
Hope i've clarified a few points and sorry about the longwinded reply.
Jim and James
Got to say the above car is the reason i am going to build a monster RST, love the fact its the same original 1600 CVH and has opended my eyes past the usual 1900/zvh conversion
Car feels rapid and imense so much so I thought my contact lenses were going to fly out of the window in the Dartford tunnel
woud be very interested to see what the full actual spec is for this car
My car is 1597cc ran 26psi on its last spec, this winter has seen new development work carried out to the car and I should have an idea on what the final spec is and its optimum performance in the coming weeks
Things are looking good though with power at its peak at 7000rpm and not tailing off untill just after 7800rpm so there's plenty to be optamistic about
Just have to wait and see how more boost effects things.
Initialy when spec'ing the car I just wanted FAST
even though the car in itself has potential for setting good time (13.9s being consistant on its 1st time up the strip). So Ive built with track in mind, as Ive had SO much fun over the past year in various other cars on track
Plans for this year; Id like to do Croft, National Day as well as a few trips out to the Nurburgring.
1.6cvh (rebuilt)
new T3 , piper cam/pulley , bayoo chip , GRS cooler , mongoose system , silicone leads , NGK , roose motorsport hoses , heat wraped turbo/manifold , 156@wheels@12.6psi@a.v.a
hope its a bit quicker now
Originally Posted by fad
Jim and James
Sorry about the late reply mate, only just discovered your post.
Apologies for any contact lense misalignment caused
7800 rpm, top
Must sound marvelous. Mine sounds amazing at about 7100/7200ish - like God's harder brother ranting at the top of his voice Would love to see some pics of the throttle bofies if you've got any.
And a trip to the ring sounds like a great idea - If PF or anyone else for that matter is thinking of organising anything; i'd deffo be up for it
Hi M8, am good thanx
High reving engines do sound great your right, Ive a small clip with the car doing a rolling burnout where the limiter was well over 8k the sound is awesome.
I can do you a couple of pic's unfortunatly they dont show the Tb's to clearly but you will get the general idea.
I'll have some new pics in the coming weeks i'll make sure take some of the throttlebodies for you.
September should be the Big Trip to the ring so start saving people
oh and get some practice in on Project Gotham 2 on the X Box and/or GT4 on the PS2
well cant wait to hear the final spec
oh and get some practice in on Project Gotham 2 on the X Box and/or GT4 on the PS2 Who did your install? (hope you don't mind me being nosey
Don't fancy posting that clip BTW do you
Sounds like she can certainly
All work has been carried out by AVA from design and production of the manifolds, throttlebodies, inlet, engine spec & build management etc etc.
I'll see if I can get someone to host the clip, and I'll post it in here for a bit, leave it with me
Oh well i guess mines the oposite end of the scale
i had a std 1.6 cvh but it snapped a ring pulling out of my street (not booting in either
so i had to get my only mode of transport going soon as .................... so i got a 1.8 zetec out of a skip which had BAD piston slap and converted it to zvh
slapped it in and off i went then i built a good one and thought i'll blow the one up in the car 1st just to see what its capable of
and guess what its still there running 180 bhp with a stg 1 chip in and i give it death everywhere i go boot it from cold the works and it still comes back for more its still in there now 9 months on with no signs of failing just yet
need more boost to blow it up hopefully fitting a stg 2 ecu soon so thats good for 18psi i hope and if it still wont blow its coming out i cant wait anymore ........................
2.1 here i come
)so i had to get my only mode of transport going soon as .................... so i got a 1.8 zetec out of a skip which had BAD piston slap and converted it to zvh
2.1 here i come
