Help to identify ECU & Oil Modine needed please.
Hi all. I need to identify the ECU below. I have been told a 4x4 engine was bought and with it came this ECU and a loom too. I have been told it has been plugged into a 2wd sapphire and it worked though? All thoughts welcomed as I need a new ECU due to some numpty literally glueing the chip into my current ECU!!
And also I now need an oil modine/cooler plate for a 2wd sapphire. Does anyone out there have one for sale please? Both of mine have succumbed to rot on the water pipes. Or an alternative to fit in it's place? I have been told they are the same as Fiesta RS Turbos? And in which case I would guess Escort RS Turbos too?
Many thanks in advance
cheeRS
cheeRS
L1, from a 3 door cossie, it has a YELLOW adjuster screw, L6 were WHITE/SILVER colour.
If not mucked about with too much some purists might pay nicely for it, it will interchange and work perfectly on a 2wd sapph L6, as will a L6 on a 3 door cossie.
The L6 was a lot better than the L1.
big_Rad
Sep 15, 2017 09:36 AM
ekjim
Aug 17, 2015 08:57 PM
Roosie
Aug 9, 2015 07:37 AM
