Boost Gauge......
Old Mar 3, 2011 | 04:11 PM
Hoogi's Avatar
Hoogi
Default Boost Gauge......
Where is the best place to "Tee" the Vaccuum Hose from for my Stack Boost Gauge.
I've been told not to break into the line for the 3 Bar Map Sensor feed.
The only other hoses I have (I think) are from the Dump Valve & Fuel Reg to the Plenum
Or do I need to tap myself a new Outlet from the Plenum ????
Old Mar 3, 2011 | 04:32 PM
opposite lock's Avatar
opposite lock
I thinks its bad practice to T into the fuel regulator i maybe wrong though? , i need to do this too , i was going to find a 2 piece connector and put this where the DV is connected .
Old Mar 3, 2011 | 05:02 PM
JonathanJ's Avatar
JonathanJ
I always keep away from the map sensor pipework as it can cause a delay in its reaction time , either a new line or t piece it into another pressure line would be better , kinda like the new line better as if a leak happens in boost gauge line then you could loose some fuel pressure as well , always try and do it fail safe is my way .
Old Mar 3, 2011 | 05:03 PM
It's best to tee somewhere other than the map, or fuel pressure reg/dv, in an ideal world.
Without an alternative though just make sure the pipes are a nice fit and secure, with no leaks, use tie wraps at each join if needed.
JamesH's Avatar
JamesH
If I had to choose between the three, I'd easily go for the dump valve
Old Mar 3, 2011 | 05:17 PM
Hoogi's Avatar
Hoogi
Cheers again Gents,
So first choice is Tap a new Take Off............Second option DV.
Just what I was after
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
