got it running but only when i hold flap down
Old Mar 3, 2011 | 03:53 PM
martin27's Avatar
martin27
Default got it running but only when i hold flap down
changed the oil to day on my s2 coz the engine woz totall flooded down to my old metering unit . finaly got it running but only when i push the metering unit flap down a bit and hold it there can any body help me out plz????//
Old Mar 3, 2011 | 04:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like you have an air leak mate.
Old Mar 3, 2011 | 04:50 PM
jamieclements's Avatar
jamieclements
defo an air leak coz my old rs turbo did that but once i found the air leak , it was fine after
Old Mar 3, 2011 | 04:59 PM
martin27's Avatar
martin27
were abouts should i be looking m8 every think wots going to metering unit is ok
Old Mar 8, 2011 | 09:22 AM
jamieclements
check all boost pipes too , slightest bit of air leaking will cause this problem
Old Mar 8, 2011 | 10:48 AM
Rob_DOHC's Avatar
Rob_DOHC
As above, all boost pipes, rocker cover, oil filler cap, dip stick, intercooler may have a hole, injector seals etcetc.
Essentially any thing that isn't air tight will cause this problem.
Your engine is running lean on start-up, or the flap isn't being pulled down due to an air leak.
If you genuinely don't have an air leak you may have a cold enrichment issue, due to a faulty sensor (air or coolant), or defective EMFPR (or what ever the acronym is).
Can you keep the car running with the flap pushed down?
Rob,
dombanks
Sep 21, 2015 08:38 PM
xrmalin
Sep 13, 2015 06:52 PM
dojj
Sep 8, 2015 08:31 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
