Cambelt snapped on 1.8D Endurance DE
Old Mar 2, 2011 | 04:32 PM
Stoogey's Avatar
Stoogey
Default Cambelt snapped on 1.8D Endurance DE
Cambelt snapped on my escort van, there was no drama about how it happened, was doing 70mph it's literally cut out with no other sounds just rolled to the side of the M3, any ideas whether it'll be sh****d or not?
Thanks
Old Mar 2, 2011 | 06:03 PM
JonathanJ's Avatar
JonathanJ
It is an interference engine , and I have known these when they go at this speed to snap camshaft and tear the cam out of the head , would just take rocker cover off and see if you can see daylight between cam and bucket and quick look at cam itself .
Old Mar 2, 2011 | 08:10 PM
Turbosimpsons's Avatar
Turbosimpsons
+1 defo goosed.
Old Mar 2, 2011 | 08:37 PM
gup's Avatar
gup
yep ive seen them crack the guides too
Old Mar 2, 2011 | 09:47 PM
Stoogey's Avatar
Stoogey
Took cam cover off and the cambelt was in 2 bits??? Don't know if something ceased maybe? Cam itself is fine no leaks or nothing around the engine bay, but I'm guessing it's game over
Old Mar 2, 2011 | 09:59 PM
botters's Avatar
botters
competant bodger
ive known the cambelt to snap at idle and still snap the cam and rip the cam carrirs out of the head as it happened to me id just started it up!
ive never known one not do damage but the only way to tell is to time it up,put a new belt on and try it who knows you could be lucky
Old Mar 3, 2011 | 08:02 AM
JonathanJ's Avatar
JonathanJ
And if you do put a cambelt on and it has not damaged anything else , get yourself down that road and get your lottery ticket put on as it must be your lucky week
Old Mar 3, 2011 | 06:39 PM
forevaford's Avatar
forevaford
1 for the recort guys, my timing belt snapped on my escort td in trafic moving slowly, put a new belt on and it fired up fine... although i did hav a tappet noise slightly so it must of caught a valve but it was fine
Old Mar 3, 2011 | 06:44 PM
Stoogey's Avatar
Stoogey
Amongst closer inspection of this internal combustion engine, I've come to the conclusion of it being f****d, but thanks for everyones input
Old Mar 3, 2011 | 06:48 PM
forevaford's Avatar
forevaford
im braking a escort with a sweat 1.8td engine??
Old Mar 3, 2011 | 07:18 PM
Stoogey's Avatar
Stoogey
Thanks for the offer mate got another one on it's way though
Old Mar 3, 2011 | 07:41 PM
burnhamshaun's Avatar
burnhamshaun
common fault for these to do this if cambelt not changed reg i had 4 escort vans and 3 cambelts snapped was doing about 50-80k a year so brought a new well used van when it happend had the belt changed then when it snapped i replaced the van got the vans from auctions my old man use to run 300-400 each
Old Mar 3, 2011 | 09:05 PM
Stoogey's Avatar
Stoogey
I had one before this where the engine was pukka done 240K and never let me down but the body was dented and rotten everywhere, now I got a mint looking one, but the engine is shagged
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
Chas
Oct 5, 2015 07:13 PM
pabloXR
Sep 21, 2015 12:42 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
