focus mk2 towbar wiring
Old Mar 1, 2011 | 08:57 PM
pne1881's Avatar
pne1881
Default focus mk2 towbar wiring
Hi
Can anyone on here describe how to wire the towbar electrics on the towbar i have just fitted?
I have bought a 'Ryder straight bypass relay' but i do not understand the instruction sheet at all. Here are some of the things i am wondering about:
  • do i have to cut existing wires?
  • the sheet talks about a power source from the battery - not sure about this?
  • does it wire into the rear lights?
The guy who i bought the bar from said it was easy - is this the case?
I could really do with a step by step guide that an idiot can understand!
Many thanks
Old Mar 1, 2011 | 08:59 PM
RichieST's Avatar
RichieST
There SHOULD be a connector behind the trim somewhere all ready for you to plug straight into, however I beleive you will need to take a trip to Ford to have the GEM re-programmed to 'turn it on'.
Old Mar 1, 2011 | 09:31 PM
pne1881's Avatar
pne1881
this bypass relay seems to have connectors for wires to go into rather than a plug in system?
Old Mar 11, 2011 | 03:57 PM
nautical555's Avatar
nautical555
Default towbar electrics
The mk2 focus can be wired without the use of the bypass relay. If the car has a bulb failure warning light, then the relay is required.
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
