st200 not locking.
Old Feb 28, 2011 | 08:10 PM
neil andeRSon's Avatar
neil andeRSon
Default st200 not locking.
as above. the car lock's then automatically open's it's self. anybody had the same problem??
Old Feb 28, 2011 | 08:14 PM
Fiddy's Avatar
Fiddy
Central locking control module is fubar, mine does the same. locks fine off the key.
Old Feb 28, 2011 | 08:20 PM
neil andeRSon
still does the same when locked with the key. i should be getting a 2.0ltr si at the wkend so i'll rob some spare's off it. whereabout's is the module?
Old Feb 28, 2011 | 10:13 PM
jackocab's Avatar
jackocab
my st24 does the same does my
Old Feb 28, 2011 | 10:54 PM
Chopshop85's Avatar
Chopshop85
Post up your address and someone will come look at the problem for you.
Old Mar 1, 2011 | 06:25 AM
neil andeRSon
Not where I am....lol
Old Mar 1, 2011 | 06:53 AM
bookwyse's Avatar
bookwyse
If it is trying to lock then it is not the central locking module. Most likely cause is a faulty.motor in one ofhe doors. Sit in the car tryto lock it and see which one.isnt.locking. Then change that mmotor over.
Jeff
Old Mar 1, 2011 | 12:47 PM
neil andeRSon
Jeff
Front passenger door ain't shifting. Cheers mate!
Old Mar 1, 2011 | 04:14 PM
bookwyse's Avatar
bookwyse
No problems, am happy to help.
Jeff
Old Mar 1, 2011 | 04:39 PM
RichieST's Avatar
RichieST
Have you tried the passenger door with the key? Give it a good greasing up it might have siezed a bit.
Old Mar 1, 2011 | 05:35 PM
neil andeRSon
It's solid. I unplugged the wiring an it now lock's. I'll try some oil around the lock an see what happens.
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
blakey100
Aug 4, 2015 08:17 PM
David82st200
Nov 5, 2006 01:30 PM
xr-stu
11
Sep 10, 2006 09:04 AM
ster
Feb 5, 2006 06:30 PM
