Bilstein GpA Cases & Other bits
Are the group a cases to suit gravel uprights Tony? Any chance you still got them? as I'm after a pair as I'm changing front end to grp a from grp n bilstein,
Link don't work as your websites been renewed and doesn't look like parts are all on there yet?
Thanks
Marc
Thanks
Marc
Takes a bit of time i suppose to get your head round it all ay lol
Had a look around the forum this morning and it looks good mate
Whats the price for the cases? do you have any photo's?, i am just weighing up a few options at the moment
Thanks
Marc
Thanks
Marc
Im going to use the forum as and when i can to get stuff moved that either has no category or is too small for its own ad on the site, i dont have any pics of cases but i know i have a pair of yellow Tarmac short cases,one has a slightly oval mounting hole but both are good to go .
ive also got some odd ones, longer gravel cases and even some 550/225 Tarmac inserts fresh from a build up .Cases are Ł100 the pair ,inserts Ł150 the pair .
i need cases the same as this Tony, whats the difference from tarmac to gravel cases?
These are what i run on the rear,
By oval mounting hole do you mean the bolt hole for securing case to upright and someone has crudely modded it for more camber?
Except these are rears so have the extra mounting for the bladed roll bar pick
PMSL ' severe mullering' is that a southern thing Tony ?
then cases are perfectly usable, especially as you have had camber washer fitted to the rears Marc, im sure you would do the same to the front ?
Marc got yer PM over there on our rally forum, I have some case, no prob, lets talk about how to get them to you, and about some shiny alloy bits I've been planning on making over here---and which it appears you're making already.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
