sierra cosworth back firing problem
Old Feb 27, 2011 | 09:08 PM
escort_shadow's Avatar
escort_shadow
Default sierra cosworth back firing problem
hi my mates got a sierra cosworth as soon as u get to 3 grand or onto boost it back fires and cuts out any ideas
Old Feb 28, 2011 | 07:04 AM
oldford's Avatar
oldford
Check crankshaft sensor and phase sensor.
Old Mar 1, 2011 | 07:09 AM
As above then check plugs/gaps try closing them a bit and see if it helps, especially check the connector on the cps by doing the wiggle test whilst idling to see if it stutters etc.
Old Mar 1, 2011 | 08:12 AM
JonathanJ's Avatar
JonathanJ
As tabetha says do a wiggle test , sounds like a HT/coil break down as soon as the plugs need more voltage to spark so closing gaps may help slightly , possibly king lead , rotor arm distributor cap , have a real close look at all these , check resistance of king lead then go from there
Old Mar 1, 2011 | 08:57 PM
escort_shadow
hi changed king lead and ht leads new rotary arm and dizzy cap and plugs also any one know the gap setting for the crank sensor
Old Mar 2, 2011 | 01:11 PM
JonathanJ's Avatar
JonathanJ
As far as I know the gap should be 0.6 to 1.0 mm , and check all 4 just to be sure that pulley is ok
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Vincereese
Aug 11, 2015 08:44 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
