re map in the south east
hi peeps
quick question been buying all the bits to make my saph go a bit quicker ie siemens injectors and so on now the time has come to get her mapped. now im not interested in an aftermarket ecu so will be sticking with my l8 ecu and a chip to suit so where would be the best place to go in the south east area that do cossie managment?
cheers
cheers
hi peeps
cheers
cheers
otherwise travel to msd/nms....
If your getting an off the shelf chip then all you need to do is just get someone to check AFR etc just to be on the safe side.
Don't need aftermarket management the L8 is perfectly capable.
Martin
Martin
it is always best to have your car mapped as every car is different and an off the shelf chip is to much of a compromise and you will never see the true potential otherwhise
as said above l8 is fine
cheers james
cheers james
