why is my escort rs turbo engine blowing the oil filler cap off but wont suck ?
Old Feb 26, 2011 | 06:07 PM
steve120283's Avatar
steve120283
Default why is my escort rs turbo engine blowing the oil filler cap off but wont suck ?
why is my escort rs turbo 16cvh engine blowing the oil filler cap off but wont suck
changed gasket, valves oil stem valve seals and still blows out of the oil filler cap but wont suck, it keeps blowing oil filler cap off it wont suck and keep oil filler cap on
any advise would be helpful asap thanks steve
Old Feb 26, 2011 | 06:08 PM
james kiely's Avatar
james kiely
piston rings ,by the sounds of it
Old Feb 26, 2011 | 06:11 PM
steve120283
if its the rings will the compression be pushing the air down passed the pistons into the sump and up through the oil filler cap
thanks steve
Old Feb 26, 2011 | 07:00 PM
james kiely
yes thats what normally happens mate ,i had my old turbo do the exact same thing
Old Feb 26, 2011 | 08:08 PM
matts1's Avatar
matts1
what are the breather pipes like? sure these being blocked and full of gunk can cause this?
Old Feb 26, 2011 | 08:12 PM
martin24uk's Avatar
martin24uk
had that problem as well, but even after cleaning them mine still popped the
cap off when the boost came on, turned out to be worn rings.
but my quick fix till i had time was to put a self tap screw threw the cap into
the rocker cover to keep it on ruff but worked a treat.
Old Feb 27, 2011 | 06:25 PM
kermitt's Avatar
kermitt
that is just a bodge. Best rebuilding ur bottom end before it gets worse and you throw a rod through the block.
Old Feb 27, 2011 | 06:49 PM
THEDMAN's Avatar
THEDMAN
I had the same problem on my track car.
Before you do anything, if you are running the OEM breather, either clear it out or buy a Bailey breather.
Worked for me, no more filler cap blown off or smoking like a bastard on overrun.
Old Mar 14, 2011 | 09:47 AM
steve120283
thanks for the help it was the rings done now
big_Rad
Sep 15, 2017 09:36 AM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
adriansaleem
Aug 1, 2015 09:28 PM
Old ford
Jul 31, 2015 06:50 AM
