Wont start from cold!
Old Feb 26, 2011 | 07:35 AM
cozzyspud's Avatar
cozzyspud
Default Wont start from cold!
Hi Guys, I've just got my cossie out of storage and when its cold it takes a good 2 to 3 minutes of near constant cranking to start it but once its warm its perfect, it has good fuel pressure and a good spark, I've changed all 3 temp sensors and its made no difference. This fault was there when I put it in storage last year but now I want it fixing, Any ideas please, NMS checked it over last year and gave it a clean bill of health but the problem is still there!
Any suggestions greatly appreciated!
Regards Paul.
Old Feb 26, 2011 | 09:25 AM
martysmartie's Avatar
martysmartie
There is only one temp sensor that being the CTS? There is another one for the gauge but this would not effect the running of the car what so ever.
Perhaps the plugs are not giving a strong enough spark? Although storage shoulden't of effected them or perhaps just damp in the ignition system from storage, I.E condensation in the dizzy?
Martin
Old Feb 26, 2011 | 02:03 PM
bruny's Avatar
bruny
Has the battery got good charge.is the fuel fresh.apparently letting a car stand for a long time the oil can go very thick and cause starting problems.car could be running very rich or lean on start up
Old Feb 26, 2011 | 03:08 PM
RS SHAUN's Avatar
RS SHAUN
Very nice on them wheels mate!
Old Feb 26, 2011 | 05:01 PM
How old is the fuel filter ?, are you getting decent pump voltage ?, has the pump been rewired ?.
The filter ideally needs doing every year, very important on stored cars, the bacteria in the fuel tank love the conditions and soon cause fuel degradation and filter issues.
If all this is ok and spark etc is ok, then the cold start mapping could well be a bit on the lean side, you could try just GENTLY squeezing the fuel return line as this will up the rail pressure, and hence more fuel whilst someone cranks it for you, if this helps you know it is lack of fuel.
Once hot check the CO is around 2- 2.5%.
Old Feb 26, 2011 | 06:29 PM
cozzyspud's Avatar
cozzyspud
Thanks for the reply's guys, I re wired the Pump last year and it was a new 044 pump and filter the year before, I think if anything it's over fuelling. It's on a L8 ecu with a MSD closed loop system on greys, I have also changed the Lambda sensor as well to no avail.
Thanks again for your reply's!
Regards Paul.
Old Feb 26, 2011 | 06:35 PM
daz-cos's Avatar
daz-cos
Set fire to it thatle get it nice and warm should start fine then mate
hope this helps. Daz
Old Feb 26, 2011 | 07:02 PM
MannheimAlex's Avatar
MannheimAlex
if it is temp related, maybe a wiring problem if the sensor change had no effect. best would be to measure through the ecu plug what kind of values you got.
Old Feb 26, 2011 | 07:15 PM
james kiely's Avatar
james kiely
have you tried for loose/broken wires in the connection blocks on your sensors paul .
i seem to remember faulty map sensor maps senors causing similar running probs too
Old Feb 27, 2011 | 09:48 AM
Regards Paul.
Obviously in that case your CO won't be, well shouldn't be anything like 2- 2.5%, I think they are nearer 0.65%, but don't quote me on that ask stu/james.
Old Feb 27, 2011 | 10:53 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Normally under 0,9% with MSD Closed Loop
Old Mar 8, 2011 | 07:17 PM
cozzyspud's Avatar
cozzyspud
Finally sorted it guys, it was the earth wire to the map sensor connection!!
Happy Days!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
