Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta Turbo Wont Idle Properly
Old Feb 25, 2011 | 06:36 PM
chris85uk1's Avatar
chris85uk1
Default Fiesta Turbo Wont Idle Properly
Hi,
My friends got a fiesta turbo and for around a week now its been running terrible, from start-up/idle the revs are fluctuating and its generally just coughing and spluttering,like its about to cut-out, when you drive it 1st/2nd/3rd gear are all the same but 4th/5th it seems to clear itself and runs fine.
Anybody had similar issues and ideas on how to rectify it?
Thanks
Chris
Old Feb 25, 2011 | 06:43 PM
Oranoco's Avatar
Oranoco
Is it chipped? If it is with the ignition off remove the chip and clean the contacts on both the chip and the ecu with a non abrasive contact cleaner (aerosol electrical contact cleaner on a clean cloth). Make sure it's completely dried out and refit.
Old Feb 25, 2011 | 06:44 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
you need to clean the icv idle control valve its on the leftside of the inlet as you look at the engine give a good soak with carb cleaner then with some wd40
Old Feb 25, 2011 | 06:50 PM
chris85uk1's Avatar
chris85uk1
Thanks for the replies
Im pretty sure its not chipped, its does have, air filter,exhaust, intercooler fitted!
Is there anything else to check over another friend suggested air leaks?
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Adam-M
22
Aug 10, 2015 10:46 AM
turbobill
Aug 9, 2015 05:21 PM
