idleing issues doing my head in
Old Feb 25, 2011 | 04:51 PM
diesel's Avatar
diesel
Default idleing issues doing my head in
as above when i start my rst s2 up it will idle ok, but if i drive down the road and come to a stop the revs will drop down to say 600 rpm or go up say 1500/1800 rpm and hold there?
so what i do is adjust the throttle cable and or the idle screw to put it back around 800/1000 rpm and buy the time i stop the next time its droped or raised again
iv changed the meter unit and still the same
my hand brake needs sorting out and when it keep stalling in traffic on a hill its a nightmare lol
any advice would be great
thanks diesel
Old Feb 25, 2011 | 05:04 PM
martysmartie's Avatar
martysmartie
I should think there is an air leak someone, this can cause havvock with the MFI system as well.
Martin
Old Feb 25, 2011 | 06:06 PM
diesel's Avatar
diesel
Martin
i have had a look for air leeks and i havent found any yet my boost gauge hisses on boost is this normal? its the first car iv had with a boost gauge so not sure if its normal
Old Feb 25, 2011 | 07:17 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
no it shouldnt do sounds like a vacume leak, best way ive found to check is get it ticking over nice and spray brake cleaner alone the inlet, vacume and breathers and see if the engine changes note
Old Feb 25, 2011 | 08:18 PM
Oranoco's Avatar
Oranoco
1st step, take dump valve off. These can cause all sorts of problems. It may not cure it but it's a very good place to start
Old Feb 25, 2011 | 08:24 PM
gingerturbo
ah well spotted, loose the dump valve.....+1 oranoco then check all the vacume pipes for perrishing, check for bad earths, does it misfire at all or just cut out
Old Feb 27, 2011 | 12:15 PM
diesel's Avatar
diesel
sorry for the late reply iv been away all weekend, its does miss abit and cut out somtimes when im slowing down after iv been booting it, i will have to try some spray like was said,
thanks again diesel
TPM961
Jan 15, 2018 10:50 AM
dombanks
Sep 21, 2015 08:38 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
